![]() Drives: 2006 YARIS RS Join Date: Jul 2009
I need to purchase some new tires for my rims.
Currently I have: Yokohame AVS ES100 (205/45 R17) on OZ Superturismo rims The tires had good traction but made too much noise and had uneven tread wear. I do a lot of city and highway driving, I am looking from some rubber that will last and not make too much noise. Any suggestions? Thanks |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
i had fuzion zri's on my camaro...much more quiet than eagle gsc (crap tires), yoko's, and bridgestones.
cooper is a good tire, and i'm shocked you're having problems with yoko's. wear issues any way, do you have it lowered? did you check the alignment? if you're feathering it may be a shock/spring issue, not a tire issue. |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Lower-profile tires will make noise, so you will have to get used to it. And like severous01 says, get that alignment done (FYI, the alignment guy may require you to get new tires before service if the worn sections are completely bald, for your own safety).
As for which tires: http://www.yarisworld.com/forums/sho...26&postcount=9 in 205/45/17
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Bridgestone potenza adrenilins are the best try and wet low noise smooth ride very grippy
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Uneven tread wear is could be an alignment issue, balance issue, inflation issue or simply due to lack of regular tire rotation. Purchasing a non-unidirectional tire will allow more options come rotation time thus extending life. Otherwise you must flip and remount the tires on the rims to move them across to the opposite side of the car. You can use the tire comparison tool at TireRack.com to see the rating of many fine tire choices. Noise level is one of several criteria indicated. NOTE: the US tire prices will either make you cry or very angry. Simply select your tire size and search, then select the tires of interest and press compare. Include your current tire as a baseline.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
falken 912's are nice
| FS: OEM Toyota Rubber Matts | CB900F2 | Items for Sale by private party | 7 | 08-16-2009 08:35 PM |
| MY RUBBER BAND BALL! AGHHH!!! | Sodium Duck | Off-topic / Other Cars / Everything else Discussions | 47 | 03-06-2009 02:56 AM |
| rubber protector sheets? | enobmort42 | Cosmetic Modifications (Exterior/Interior) | 0 | 02-25-2009 11:41 AM |
| Rubber plugs in glove box | cfiimei | DIY / Maintenance / Service | 5 | 01-06-2009 05:48 AM |
| Yaris Rubber Floormats? | galaxyhillvt | Cosmetic Modifications (Exterior/Interior) | 18 | 11-26-2006 08:52 PM |
