Old 11-28-2011, 05:00 PM   #1
susucosp
Drives: toyota yaris
transmission fluid that indicate must change
can anyone tell me what color and smell of the transmission fluid that will require change. if it does not need to be change, that is the best. i check the stick of the transmission oil with a white tissue paper, the color look like brownish when wet but when dry on the white tissue paper, it look like purple in color. i try to smell, and cannot smell nothing burn smell. so, do i need to change the transmission fluid at all?
my car is reach 100K miles, front disk brake never need change, it is still like new. i only change the rear drum brake of my car, of course, i have to change oil, and filter, air filter, battery, tire, make tire rotate, wind shield wiper, spark plug, ...
susucosp is offline   Reply With Quote
Old 12-07-2011, 02:49 AM   #2
rene0023
rene0023's Avatar
Drives: Scion FR-S 2013
Coqui, Coqui...
rene0023 is offline   Reply With Quote
Old 12-07-2011, 09:04 AM   #3
The AT Fluid discolors from bright red to a purplish or brownish red over time due to heat and contaminants. The service manual says that the fluid is a lifetime of the tranny fluid, and without the burnt smell, it is probably still OK.
Old 12-11-2011, 12:51 AM   #4
TheEgg
Drives: 07 Yaris HB (The Egg)
It won't hurt it to do a little preventative maintenance and have the transmission flushed. The thought of any manufactures stating they have an extended service life on the fluids doesn't seem right to me. Transmission fluid will break down over time no matter how perfect they make it sound.
TheEgg is offline   Reply With Quote
auto transmission fluid change bribri DIY / Maintenance / Service 4 01-01-2012 11:39 AM
Oil Change and Transmission Fluid ras3448 Third Gen Yaris General Discussion 2 09-15-2011 02:05 AM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
Manual Transmission fluid change bankrobber DIY / Maintenance / Service 1 01-17-2010 11:32 AM
