Old 09-24-2009, 06:15 PM   #1
pEAchEzpwnz
pEAchEzpwnz's Avatar
Drives: 09 liftback yellow jolt
speedometer lights
Is it normal for the speedometer display lights to get dimmer when you turn on your lights at night? My car is only 7 months old and just began doing this.
pEAchEzpwnz is offline   Reply With Quote
Old 09-24-2009, 06:29 PM   #2
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Yes, That way they do not blind you at night. BTW check your dimmer switch.
POORSHA is offline   Reply With Quote
Old 09-24-2009, 06:33 PM   #3
Maxh91
Maxh91's Avatar
Drives: Red 3 Dr HB 2008 Auto.
Try this
*Edit*: someone was faster than me!
Maxh91 is offline   Reply With Quote
Old 09-24-2009, 07:47 PM   #4
pEAchEzpwnz
ye i know about that. I did try it..its already on max. I recently cracked open my headlights so I could paint the inside of them black, but I made sure to put and wire everything back properly. This started probably after a week of doing that project.
Old 09-24-2009, 09:08 PM   #5
b_hickman11
Drives: 08 Sedan
The dash lights are suppose to dim whenever you turn on your headlights, day or night. This is how most if not all cars are setup.
b_hickman11 is offline   Reply With Quote
Old 09-24-2009, 09:33 PM   #6
pEAchEzpwnz
O ok. Thanks for the help! I was just checking because it never did that before, so I thought maybe I messed something up when working on my car
Old 09-25-2009, 03:00 AM   #7
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
If your dimmer switch is actually set at 'max' then the dash lights should not dim at all when you turn on your headlights.
The dimmer switch has a 'stop' you have to push past to 'click' it into the actual maximum setting. Make sure you're past the stop and clicked into max, if your dashboard lights still dim at all, you have an electrical problem somewhere.
WolfWings is offline   Reply With Quote
Old 09-25-2009, 12:34 PM   #8
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
in all actuality I made a thread about something similar to this a while back about on the sedans dimmer rheostat. when you turn the dimmer switch all the way up it goes bright then after the click it turns dimmer (with headlights on).
CLICK HERE FOR THE THREAD
ok NVM.... I didn't fully read your post, plus the fact you have a liftback....sorry
Old 04-20-2020, 10:02 PM   #9
blktiger60
blktiger60's Avatar
Drives: `08 HB S
I would say most cars that have an adjustment control have both max on always setting and a variable setting
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 08:54 AM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 11:38 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 10:24 AM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 02:45 AM
