aka SDMF
yakima double down help
ok so i recently got back into biking and i purchased the hitch rack. everything was going good for a while till the plastic bike cages are always loosening up. anyone with a fix to stop them from moving? im thinking electrical tape or plastidip around the cages to prevent cage from moving. just wanted to know if someone has a better idea. thanks.
Learn to Relax
Would electrical zip ties work?
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
staypuft,
If you open the large fittings a bit they put pressure on the bar and stay put. If you make sure the smaller fitting's retaining rings are flush to the bars they will usually stay put. If you drive aggressively while bicycles are loaded they will still move some, so take it easy. Edit: These items are considered consumable, as are the rubber straps, so don't be surprised if after 2 years of heavy use you need to replace these things.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. Last edited by BailOut; 04-18-2010 at 11:45 AM. |
aka SDMF
its been really windy and i usually go 55-60 while transporting my bike. usually the one with the stabilizer is ok the one that moves is the single one with the rotating lever
| Yakima Roof Rack - $200/bro | galaxyhillvt | Items for Sale by private party | 14 | 04-14-2011 09:45 AM |
| Is Yaris HB 2007 Double Din or Single Din? | ediaz_pr | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 04-09-2010 08:41 PM |
| Yakima Roof Rack for sale | galaxyhillvt | Items for Sale by private party | 5 | 06-03-2009 02:00 AM |
| FS: Yakima Roof Rack System | KG4GYV | Items for Sale by private party | 5 | 03-31-2009 11:23 AM |
| Yakima rails on hatchback | gbrunner | Cosmetic Modifications (Exterior/Interior) | 4 | 08-23-2007 12:07 PM |
