MPG Hog
Drives: 2007 Yaris Sedan Join Date: May 2010
Do I have ABS?
I have the 2007 Sedan Base with Power Package. Does the power package provide ABS, or was that a separate option? I know the for sure way of finding out, but I would rather not
Half a Bubble Off Plumb
We've got a 2007 S Sedan with Power Package. No ABS. It was a separate option, I believe, and quite rare. It became standard on the 2009 models.
MPG Hog
Really? Because I did some research between the time I posted and when you replied and I found the official Toyota .pdf for the 2007 Yaris and it states that the power package for the Sedan and S Sedan included ABS with EBD. Weird.
2007 Yaris did not have ABS
2008 ABS only with Power Package 2009 Standard on all Yaris's |
Drives: 07 sedan Join Date: Mar 2010
Where are you guys getting this information about ABS being rare? Its an option, but I know for a fact there were yarii at the dealership with ABS when I bought my yaris in early 07... and iirc every S had ABS.
Its not that scary finding out the "hard way" just get some good open road and press as hard as you can at 45. You can let up the second they start squealing if you don't have ABS, just keep the wheel steady. |
MPG Hog
I have confirmed that my 07 Yaris does indeed have ABS. I took it for a little drive :)
#7 | |
DAT'S RIGHT I GOTz 2
![]() easy way is to look under the hood trace the b-lines off the b-master if you see a box with like 4 steel lines coming off it you have ABS or turn the key on acc there is usually a light (ABS) on display
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Here's a weird one for ya... I have the base model 2007 LB and it definitely does not have ABS (nor do I need it). There is no indicator light, no "box" in the brake line system, no pedal pulsations when I brake hard.
Yet when the 2 insurance companies I've used have pulled up the VIN it shows that the car does have ABS, and they each have given me a discount for it even after I've told them that it doesn't have it.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
+1 with my insurance company, and still I lock-up sometimes through canyons lol
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
| ABS LIGHT & E BRAKE LIGHT | rossman | DIY / Maintenance / Service | 5 | 02-25-2010 11:09 PM |
| Adding ABS to a Yaris | tadc | Performance Modifications | 1 | 02-14-2010 03:56 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
| ABS....Again~~ | MeggiemobileSFLA | DIY / Maintenance / Service | 11 | 04-03-2007 09:12 AM |
| ABS Virgin!!! | yaris-intuit | General Yaris / Vitz Discussion | 23 | 11-29-2006 12:49 PM |
