Sub/Amp Question Re: Impedence Load
Okay...quick question...
Can I drive four of these: http://www.infinitysystems.com/car/p...=US&Region=USA off one of these: http://www.alpine-usa.com/US-en/prod...del=PDX-1.1000 Or will ohm load be too low and burn amp/subs? Also, can someone post the math behind this, so I can understand it? Thanks, - H
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
Oh and how much power will be making it to each sub? Thanks...
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
That amp puts out the same power at 2 or 4 ohms(1000 watts at 14.4 volts at 1% thd). With 4 4 ohm subs you would want to run a series parallel configuration to end up at 4 ohms. That puts you at 250 watts each.
Disregarding the ohm load labels, is this the proper wiring sequence of which you speak?
Thanks,
Yes sir.
Thank you Palmer!
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
