![]() Drives: 2007 Yaris 2 Door HB Join Date: Apr 2010
Performamance Chips
Does anyone know anything about Performanace Chips? I understand that they are suppose to either increase your hourse power at the wheels or increase your gas mileage or both. I've seen them on ebay but frankly they sound to good to be true.
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
There is no "chip" available for the Yaris. For most cars today "chips" are not used. Most cars today will either use a program to reflash the ECU or use a handheld programmer to modify the ECU.
Modded Moderator
If it sounds to good to be true it probably is.
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
i used lt1 edit on my camaro. and i had no problems with it. now, certain computers will set a 12v high on the ground pin for the ALDL connector, but that's a computer issue....
any way, it was easy. use a laptop with a program, hook up through obd port, run program...once program is up, it was as easy as a 3d picture of your air/fuel map and power ratings...or, a 2d setup that was a fuel, air, timing, and several other options. you can set timing, advance or retard timing, create several files and update at track for track fuel and then change it on the way home...whatever. the program was 60 bux and another 20 for the actual stock lt1 file to be edited. so less than a hundred and a laptop i bought off ebay for 100 bux. less than a handheld 'power programmer' from any major name brand. |
lol? Is there any reason everyone has danced around the actual question?
"Performance Chips" are just plastic casings with a single resistor inside. So no, they do nothing. |
#6 | |
) Not helpful at all for the yaris. Just wanted to drop my newfound knowledge.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
We just need to get cobbtuning.com to make one for us.
I should have known since I couldn't find anything about performance chips anywhere on this site that they were some type of rip-off. Thanks everyone!
Modded Moderator
I really wish ebay would ban these things like they do selling children or used underpants.
i'm not talking 'chip'.
i'm talking ECU programming with enhanced fuel/air curve, timing change for premium fuel, top rev limit cut off (like the yaris needs it, but it's nice to know if i do a 2jz swap i'm good for the 200mph), and whatever else i want changed...an ECU flash if you will, that i can update at any time through the use of a laptop and an ALDL cable. a simple user-interface program will do nicely. all it takes is breaking the toyota code...which i have no idea why it's so hard. |
^ because reverse engineering machine code is hard.
No one wants to spend months on it (at best) with no help from Toyota. Maybe someday, when the tuner market for this car is bigger. |
i understand. i wouldnt even have the patience to think about doing some code breaking. but, still, someone out there has to have knowledge and the willpower to spend countless hours on a program and then make a few bucks out of the deal for each sale. i'd pay a hundred bux for a program and 25 for each set of codes. a code for intake/exhaust, a code for head/cam, a code for s/c or turbo, and a code for nos or whatever...i'd pay the price as long as it wasnt rape
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
changing the map without changing intake, injectors, cam, pistons, and exhaust will
either A) not do jack or B) burn the motor up it is possible to get amazing fuel economy without hardware, just engine maps... but the valves will melt and cat will destroy itself, amongst other things performance chips from ebay=scam. 75 bucks or less, scam city carefully built and engineered parts, along with ECU programming = power or economy (very expensive) |
i got almost 45 real horsepower out my camaro with a tune. no injectors or nothing...and when i got my injectors and i got my exhaust, stroked the engine, ported heads and all the other stuff i did...i continually upgraded the maps to reflect the upgrades.
here's the deal...as a base tune your timing is way off, so far retarded it's pathetic. so, with premium gas and a advanced timing, you could easily not only improve FE, but also increase power. so you get better power with deeper throttle and more economy with less throttle, all using advance timing and premium gas. i'm not saying dump enough fuel to drown the cats, or lean it out so much you burn valves which is what you're saying...i'm saying advance timing so far that it requires premium gas. advance timing plus slower burning fuel adds more bang for the buck. quite literally. |
| Stone Chips | Ryu | General Yaris / Vitz Discussion | 3 | 03-12-2010 12:31 PM |
| Got some chips on the Yaris from my 100 miles commute, any suggestions for a fix? | firebird1999us | DIY / Maintenance / Service | 6 | 04-26-2009 01:53 AM |
| Stone chips & rust spots | devinlamothe | Wash, Wax, Detailing, Exterior Repairs | 5 | 03-12-2009 04:36 PM |
| ebay chips | TinyGiant | Performance Modifications | 12 | 10-22-2008 09:34 PM |
| Stone Chips | RandomPilar | Wash, Wax, Detailing, Exterior Repairs | 9 | 08-15-2007 03:52 PM |
