'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Rostra cruise control issue
I need help with where to begin. The dealer installed rostra cruise kit shuts off intermittently and sometimes but not always, on bumps in the road. Dealer could'nt reproduce concern, obviously. Anyone, maybe CTScott lol, have any ideas on where to start? Im gonna look first at the. Connector ends to ensure they're tight. after that dunno what to check. Thanks in advance!!
90% odds that its a loose connector somewhere.
If the dealer installed it, they should fix it. |
#3 | |
at any rate I actually was hoping someone might have the diagram handy of the wiring diagram for it.....if not I will check the company site for a possiblity.... |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I have a problem with the brake pedal stop light switch being too sensitive/ill adjusted, so when going over bumps, the brake lights turn on intermittently. That also turns off the cc when hitting bumps. You can drive at night and put a piece of paper in the rear window to make it easier to tell if your brake lights are on when they shouldn't be.
I fixed it by jammig a double sided piece of scotch tape on the tip of the stop light switch. |
Along the same idea, if yours is manual, check the tightness of the clutch switch. Since it is happening on bumps, it may be due to those pedals moving aRound sensitive switches.
UPDATE:::: Finally got a tech to test drive with me, confirmed that rostra cruise is now not working at all, stalk light comes on but cruise will not engage...FINALLY! 3 years of this issue.....I'll update with fix/repair when performed
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 03:21 PM |
| A Sub 4 Rostra cruise control (am in Texas) | elo79 | Performance Modifications | 9 | 12-19-2006 03:35 PM |
