Old 06-08-2010, 02:25 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
UPDATE on PG spacer.. 13mm left/10mm right
for future fitting for new user..try to have the left rear 4mm more than the right to make it even vs right rear wheel spacing only for hatchbacks.. i cannot confirm sedans...
AS we all know our yaris hatchback had issues with left rear being tucked in more than the right so i did the unexpected and ordered 2 offset spacers fr garm.. 1x 13mm (which goes on the left and 1x10mm for the right.. guest what..almost had it to match..i figures the left is about 4mm-5mm off but the extra 3mm did come close.. also confirmed that its the frame thats crooked not the body. the way i did this was to lined up the front tires/rims to the back noticeably off from the front also comparative to the right side..
now the 2nd issue with 13mm on the left and 10mm on the right is i still rub on both sides during dips..hitting a small lip connecting the metal frame to the plastic rear bumper..good thing is its almost even hit might be off by 2 mm so now dont know what to do. by the way im running 205/50/16 +40 offset on a trd spring
1. spend $70 to roll UP LESS THAN 2 inch LENGTH lip issue
2. roll it my self using bat or something or just use pliers and fold it up..
3. grind it
(Wood) TB Spacer for Yaris Y@R15 Performance Modifications 13 10-01-2009 05:31 PM
Wheel/hub spacer, PLS help evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-18-2009 03:21 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
Quality Chrome license Plate Frame? blacksan Cosmetic Modifications (Exterior/Interior) 2 05-08-2007 08:45 PM
Rolling frame rail and bracket removal mikeukrainetz DIY / Maintenance / Service 6 11-23-2006 02:28 PM
