Old 06-01-2010, 03:59 AM   #1
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
HELP!!! HEADLIGHT QUESTION
So I put a HID kit in 3rd day and then they go out. I check the wires its good. The actual connector where the stock lights plug into look a lil damaged like... fried =\ So I put the stock ones back in the and the passenger side works but the drivers side is really dim?!?!!? Did I totally screw up the plug for the lights? I need help nowwwwww
falkor_99 is offline   Reply With Quote
Old 06-01-2010, 06:46 AM   #2
window_lee
Drives: Yaris RS 2007
i got the same problem b4, and i took my car to the dealership and they just replace a fuse or a relay then it back to normal
don't forget to put your stock light and bulb back b4 you take your car to the dealership
window_lee is offline   Reply With Quote
Old 06-01-2010, 09:07 AM   #3
Check the H-LP LH fuse (in the under hood fuse panel).
Old 06-01-2010, 09:50 AM   #4
falkor_99
falkor_99's Avatar
Sweet, thanks. I'll check the fuse box. And then if that doesn't work I guess I will have to take it to the dealership =\
Old 06-01-2010, 11:16 AM   #5
If that doesn't work, let me know and I'll point you where to look next. As long as you have a volt meter it should be pretty easy to track down the problem.
Old 06-01-2010, 12:22 PM   #6
falkor_99
falkor_99's Avatar
You sir are a genious =D I checked the fuse and it was blown. So I put the horn one in there for now. Never liked the way horn sounded anyways =P
Old 06-03-2010, 11:59 AM   #7
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Lol
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 09:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 03:12 AM
Headlight adjustment screw question. evan DIY / Maintenance / Service 6 01-09-2009 06:58 PM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 10:54 AM
