Old 05-28-2010, 03:11 PM   #1
dante2086
Drives: Toyota Yaris 07
HELP, my car is acting up!!!
I tried to rewire the dimmer assembly as the switch is missing and I couldn't find it to purchase.
I made the mistake of cutting off the 10 pin connector to do this, and now it's like the car has gone beserk.
The battery isn't charging, the airbag isn't working, the ABS isn't working, the power steering isn't working, the gear isn't shifting. It's like the car is dying, Help please anyone.
dante2086 is offline   Reply With Quote
Old 05-28-2010, 03:49 PM   #2
Check the GAUGE and PANEL1 fuses (under the dash).
Old 05-28-2010, 04:00 PM   #3
dante2086
Panel 1 fuses i get, but what about this GAUGE thinggy
Old 05-28-2010, 05:33 PM   #4
They are both fuses in the under dash fuse panel.
Old 05-28-2010, 05:49 PM   #5
dante2086
Thanks, I'll try it. But I'm curious, if I was suppose to connect the light green wire, to the black/white wire, and the orange wire. Then where is the power supposed to come from.
Old 05-28-2010, 06:11 PM   #6
The dimmer rheostat brings the ground for the interior lighting from ground to +12 volts to do the dimming. Ground = full bright, +12 = completely off, in between = some amount of dimming.
Connecting the green and orange right to ground will give both of those circuits their ground (instead of an open circuit with the rheostat removed).
Old 05-29-2010, 01:25 AM   #7
dante2086
I checked the fuses and they're blown. I changed them, and now the car is back to normal. Ur quite the genius, THANKS. Can u tell me why they blew up in the first place?
And can the dimmer be rewired without the connector.
Cause I don't wanna make any mistakes again. And pls, what fuse controls the dash lights?
THANKS. I owe u five.
Old 05-29-2010, 12:15 PM   #8
The way that I posted in the other thread should allow you to make it work without the dimmer. Just, make sure you make your connections with the car off and cap off the remaining unused wires to avoid an accidental short and more popped fuses.
Old 05-29-2010, 09:23 AM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Did you cut the wires with the key ON?
Old 05-29-2010, 02:13 PM   #10
dante2086
Alright, got it. Thanks
Old 06-01-2010, 11:41 AM   #11
dante2086
Hey, what's up.
If I'm not mistaken, the guidelines u gave me will supply light to the ac switches, radio, hazard lights etc.
By earthing the orange and light green wire.
What about the gauges (the cluster), they too don't come on, am I also to connect the yellow wire directly to the earth for them to come on.
THANKS.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Tata Motors to introduce Air Car - Is it the next big thing? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 24 09-29-2010 11:42 AM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
Darb - Photo Scavenger Hunt Darb Photo-Video-Media Gallery 3 03-01-2009 09:02 PM
