![]() ![]() ![]() Drives: 08 Yaris HB Join Date: Nov 2009
Would 6.5" speakers fit the front without modification? or am I just best off buying 5.25" speakers? Another questions, is 100W or 150W sufficient for a sub-woofer in the yaris? anyone running this kinda of wattage on their sub?
Thanks yarisworld!! |
Roadrunner Jr.
...'modification' is such a funny word. You should be just fine with the 6.5. If anything you might fab up a .5'' baffle. It's easy. As for the sub wattage, t depends on the sub and the user's tastes.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
I just looking for a sub that completes the sounds. I'm not looking to have the car thumping like crazy. I just want a clean crisp bass. I was looking at a 100W JL audio vs. a 150W kicker sub.
Roadrunner Jr.
Which JL and which Kicker? Clean crisp bass? I'd go for an ID8 in a .45^3 sealed enclosure. Lotsa output on that little 8" woofer. It's not too expensive either. What amp are you looking at for the JL or Kicker? Watch yourself with the online purchases...
Secret Agent
Drives: 2008 Yaris Hatch Join Date: Feb 2009
6.5" will fit in the front doors. Watch the depth. You might have to trim a little. I took a hacksaw blade and cut out the center of the stock speakers, and just mounted the new speakers on the plastic ring.
Sorry, but I didn't take any photos. If you drill out the rivets, and remove the entire speaker, you will probably need to use adapter rings. You can make them yourself out of some 3/4" MDF. You need some bass? Here is a cheap solution:
www.sonicelectronix.com for all your mobile audio needs! |
Audio Junky
an 8" is a little small imo (i'm running dual 8's currently). Go with a 10", higher efficiency so it'll get louder with the same amount of wattage, and will play a little lower (all variables being the same.... which they never are).
I'd always pick JL over Kicker unless you are aiming to be obnoxious and loud. JL makes quality products, kicker... errr.... they cater to those who want to be loud. |
#7 | |
As far as amp goes. I haven't really looked into that yet until i have decided on a sub. |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
