Old 11-11-2010, 07:23 PM   #1
auto pal
Drives: 2008 toyota vios 1.5G A/T
macpherson struts or brakes creaking?
hello.
i have a 2008 automatic sedan. my odometer reads about 38K kilometers.
i have been feeling or hearing a creaking sound coming from the front of the car when braking. more so, if it's a sudden hard stop. i don't know if it's from the brakes or the macpherson struts. also up front, there's a slight knocking or clunking sound when the brakes are applied.
are these problems connected? are they common? what could they be?
thanks for any advice.
auto pal is offline   Reply With Quote
Old 11-12-2010, 12:59 AM   #2
yaris2010RS
yaris2010RS's Avatar
i think only a mod can move it. but ur noise, i hear a light clunk when brakes are applied the first time after being in reverse and going forward. my dads ML500 had the same issue from new (only it was alot louder) and he was told its the break pads moving front and back and its nothing serious.
i would check and make sure ur wheel studs are tight. also has any work been done to the front end of the car? i would start there. in very rare cases ive heard of ball joint making this sound.
Strange creaking sound whenever applying brakes at stop position. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-04-2015 04:51 PM
Is this idle characteristic a problem? Shinare DIY / Maintenance / Service 11 01-16-2012 07:02 PM
macpherson struts or front disc brakes sounds? auto pal DIY / Maintenance / Service 6 11-17-2010 06:50 AM
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
