Old 06-08-2010, 03:00 PM   #1
sberdina
Drives: Yaris Sedan 2008 1.3 16V
Changing the antenna on Sedan
Hi,
My question : how can I change the antenna or improve my radio signal reception strength in my Sedan ?
Thanks.
sberdina is offline   Reply With Quote
Old 06-08-2010, 03:02 PM   #2
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
my sedan doesnt have antenna...?
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 06-08-2010, 03:09 PM   #3
sberdina
The antenna is in the rear glass, in fact it is not an antenna but a wire on the glass.
I want to install one, because that kind of antenna is meant to be used in towns not in remote areas.
Old 06-08-2010, 04:51 PM   #4
severous01
those are awesome. i used one in the city where i was...
Old 06-08-2010, 10:40 PM   #5
b_hickman11
Drives: 08 Sedan
I live in a remote area and I have no problem picking up stations.
Old 06-09-2010, 04:01 AM   #6
sberdina
I live now in the Sahara Desert, there is no AM radio antenna 400 km around, that's why I need a stronger antenna. The closest FM transmitter is 100 km away.
Old 06-09-2010, 05:44 AM   #7
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I guess you could put a LB antenna on it with some roof modification... I think there might be some signal amps that could be installed inline between the antenna and the radio. In fact I just found an FM booster here
Old 06-09-2010, 02:39 PM   #8
sberdina
I thought about installing an antenna directly at the end of the existing antenna wiring, but according to the Yaris maintenance manual I should remove the roof plastics and so on.
Now I am thinking of plugging directly another antenna somewhere in the start of the wiring not far from the radio receiver ..
Old 06-09-2010, 10:32 PM   #9
b_hickman11
Drives: 08 Sedan
AM radio? They still have that?
Old 06-10-2010, 10:28 AM   #10
sberdina
In North Africa yes (Algeria), there are very large desert area here and the AM is the best modulation for the desert.
Old 06-10-2010, 11:26 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
Im wondering the same thing. Ever since i had my windows tinted it seems like even my local stations dont come in clear now.
Old 06-10-2010, 02:08 PM   #12
CtrlAltDefeat
I ♥ Yaris
Thats weird... I'd call BS but I don't know all the details... are they metallic tint? I can't imagine tint interfering with a radio signal unless, maybe, it was metallic (or maybe the tint shop damaged the antenna)...
Old 06-11-2010, 04:17 AM   #13
sberdina
plastic tint do not affect radio waves at all.
Old 06-11-2010, 10:20 PM   #14
YarisSedan
It was suntek brand i think. Which is semi metallic not ceramic like 3m. Or could be they may have damaged the antenna when doing it.
Old 06-11-2010, 10:23 PM   #15
YarisSedan
I am thinknig of trying something like this
http://www.crutchfield.com/S-kSvW7bG...Amplifier.html
Old 06-11-2010, 11:41 PM   #16
I may be mistaken, but I think the glass antenna is for FM only, the AM antenna would be built into the head unit, since they use completely different wavelengths? Something to look into!
Old 06-12-2010, 05:43 AM   #17
CtrlAltDefeat
I ♥ Yaris
Isn't that what I posted above?
That sounds really familiar... I wonder if that's true.
Old 06-12-2010, 12:24 PM   #18
WolfWings
WolfWings's Avatar
Get a CB antenna, such as a FireStik, up to a 4-foot model is perfectly safe to mount on the roof as long as you get the light-weight spring, not the medium-heavy-weight one. You'll need to punch a 1/2" hole in somewhere in your car, but you'll get astronomical radio reception then with a CB to AM/FM splitter box.
The CB antenna wiring will be higher quality and more sealed (signal-wise) than the stock radio antenna, too, so the signal will stay clearer of interference.
Where I can install the GPS external antenna for Yaris Sedan 2007 DerKaiZeRs In Car Entertainment + Electronics (audio / video / alarm) 4 10-02-2009 12:24 PM
Sedan Antenna CanadianHiFive2 Cosmetic Modifications (Exterior/Interior) 2 03-14-2009 11:54 PM
Are those short antenna will fit a yaris sedan??? mariosuper Cosmetic Modifications (Exterior/Interior) 7 09-11-2006 06:53 PM
