Old 06-29-2010, 03:25 PM   #1
arckeymolarkey
Drives: Yaris
No sound!?
So i hooked up my amp today.. everything went well tapped into the correct acc pin as stated in the sticky turned the car on amp on stereo on life is good.. I turned up the stereo loud to see how it sounded and then the radio just shut off. Seemed to like overload or something. I checked the fuses and they are fine radio comes on all accessories work but no sound at all... any ideas?
arckeymolarkey is offline   Reply With Quote
Old 06-29-2010, 04:25 PM   #2
Check the fuse for your amp.
Old 06-29-2010, 04:42 PM   #3
arckeymolarkey
Drives: Yaris
Fuse is fine.. think it is possible that the output from the factory headunit is fried? I'd hope not since that is what they make fuses for.
Old 06-29-2010, 08:16 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
make sure your wire which you used to tap into the acc wire is cleanly connected, look for stray conductors (single strand wires) that may have frayed off and be touching something they aren't supposed to.
I've done exactly what you've done and have no problems.... so unless there is a bad/weird connection somewhere i'm not sure whats up.
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
My other sound, suspension? N9QGS DIY / Maintenance / Service 2 10-19-2009 02:26 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
