Old 06-25-2010, 09:23 PM   #1
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
oem Cigarette lighter option
was the yaris offered with a cig lighter option from Toyota? I have a 07 lb and want to install a cig lighter..
thanks in advance
Ben
DeathBeard is offline   Reply With Quote
Old 06-25-2010, 09:27 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Not that I'm aware of. But it does come with a 12v outlet so it should be an easy swap to make that a cig lighter.
Old 06-25-2010, 09:46 PM   #3
There's a kit that includes the lighter and an ashtray that mounts in the storage area below the outlet.
Old 06-25-2010, 10:39 PM   #4
DeathBeard
DeathBeard's Avatar
is that yaris specific? i cant find the part number anywhere
Old 06-25-2010, 11:01 PM   #5
It's a genuine Toyota accessory for the Yaris. I don't see it listed in the US accessory list, but it is listed on the Canadian one:
http://www.toyota.ca/cgi-bin/WebObje...age=english%3E
Old 06-25-2010, 11:39 PM   #6
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Maybe this is a silly question, but aren't all automotive 12V power outlets the same? Couldn't you just go down to your local auto parts store and buy a cigarette lighter to plug into your existing outlet?
Or does the '07 not have the power outlet?
Stove is offline   Reply With Quote
Old 06-26-2010, 09:18 AM   #7
That is true - The Toyota lighter is no different than any other, except for having the logo on it.
Old 06-26-2010, 12:17 PM   #8
Altitude
Altitude's Avatar
I don't think the 12v outlets are designed to handle the heat that would be generated by a lighter nor are they designed to handle the push-in , pop-out when hot function of a lighter (the contacts at the base of a lighter socket form a clip to hold the heating element while it heats up whereas a 12v socket just has a flat contact point.)
You can buy generic lighters that come with both the socket and the lighter element at just about any auto parts place.
Old 06-26-2010, 12:37 PM   #9
I don't think that the socket needs to be replaced. The kit, just contains the lighter and the ashtray, not a replacement socket. Also, the EWD calls the socket the cigarette lighter.
Old 06-27-2010, 11:06 PM   #10
DeathBeard
DeathBeard's Avatar
CTScott thank you! How can I find the part number for this? The page you linked doesn't list the part number?
Old 06-27-2010, 11:22 PM   #11
I haven't seen a part number for it. I would try either your local dealer or TRDSparks.com to see if they can get it and/or have the part number for it.
Old 06-27-2010, 11:50 PM   #12
http://www.trdsparks.com/displaypart...&parts_id=1121
Old 06-28-2010, 12:48 AM   #13
coheed
Drives: 08 BB LB
The 12v outlet we have doesnt work with cigarette lighters. I've tried 4 different ones. 2 stock Toyota ones and none of them supply any heat after any amount of time in the outlet.
Old 06-28-2010, 07:29 AM   #14
Interesting - So in that case the Yaris specific kit that thebarber posted the link to must be required. There must be something different about the positive contact (the one at the tip) that prevents generic ones from working.
Old 06-28-2010, 10:02 AM   #15
DeathBeard
DeathBeard's Avatar
The factory Yaris one has a specific connector that plugs into the oem cabin harness..my results with aftermarket cig lighters has been less than stellar
How do I remove my cigarette lighter? swayney Cosmetic Modifications (Exterior/Interior) 19 01-07-2016 01:36 PM
Cigarette Lighter Fuse stellar DIY / Maintenance / Service 10 01-30-2010 03:08 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 10:08 AM
In-car Cigarette Lighter problem jonr0613 In Car Entertainment + Electronics (audio / video / alarm) 10 10-14-2009 12:16 AM
cigarette lighter assmebly no power? csheller In Car Entertainment + Electronics (audio / video / alarm) 6 09-23-2007 07:18 PM
