Old 02-18-2009, 01:54 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
My Subwoofer inverted!
Here are some pics of my subwoofer from my ongoing audio install.....
fuji is offline   Reply With Quote
Old 02-18-2009, 09:21 AM   #2
FEINT
FEINT's Avatar
Drives: Vitz RS 1.5
Thats a really big woofer. Nice grounding cable! :)
FEINT is offline   Reply With Quote
Old 02-18-2009, 10:16 AM   #3
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Is that the gorgeous DIYMA 12
PG TLD22 8V Line Driver
Old 02-18-2009, 10:31 AM   #4
what's the internal volume of that enclosure?
Old 02-18-2009, 12:30 PM   #5
fuji
fuji's Avatar
Yes, it is a DIYMA12. It came with some dents in the cone so I decided to invert it. It was also pretty scratched up on the back side as well. I think it was the quality of the chrome job. I took a porter random orbital with a bunch of mother chrome polish and went to town for a half hour. it took out almost all the marks and scratches.
It also needs a very small volume. You can go as small as 0.5 cubic feet. I decided to go a bit bigger given some reports are it sound a bit better in an enclosure around 0.75. This make it a pretty ideal subwoofer for our cars.
The other thoughts I had was dual JL audio 6w3 or 8w3v2.
DIYMA12 are available on ebay from NPDANG(great seller from diymobileaudio.com)
Also this is a SQ subwoofer - it is not meant to rattle the car of create ear deafening boom
Old 02-18-2009, 12:40 PM   #6
fuji
fuji's Avatar
The whole car has also been sound dampened with Raamat, damplifier pro, a bunch of solarflex(works pretty well and cheap) and 2" memory foam.
Old 02-19-2009, 02:39 AM   #7
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
nice setup! must see one day. so what was the estimated cost for this project?
808_Yaris is offline   Reply With Quote
Old 02-19-2009, 10:03 PM   #8
fuji
fuji's Avatar
The subwoofer was $125 + about 80$ in shipping The box was really cheap at about $40. It is meant for a truck 12". I then added a bunch or resin and chopped fiberglass to the inside the stiffen it up a bit(3 layers. Nothing is going to make that little box flex!
Overall the project cost about $250.
Old 02-21-2009, 02:09 PM   #9
fuji
fuji's Avatar
Here is the Zapco amp and the wiring for the install. Just wish I had more time to get this done. I also have the fronts to get in as well.
Old 02-22-2009, 04:51 PM   #10
FcukThis
Drives: yaris
How do you like the sub?
I tested some and hated them. Far too transparent for me.
FcukThis is offline   Reply With Quote
Old 02-23-2009, 11:40 PM   #11
fuji
fuji's Avatar
A transparent sub without too much boom is what I was looking for. Sounds kind of strange. I just want a sub which will fill in the bottom end with very accurate bass.
Old 02-25-2009, 12:30 AM   #12
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
nice setup......I need to get the Knu cable ends for my wires like you have....very nice.
Old 02-26-2009, 11:54 AM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You seem like you're having fun! I like that idea of saving a little money and still having great sound. I'd come listen to the system but, I'm staying on the mainland. What's the plan for the components?
― Thomas Paine
Old 02-27-2009, 02:06 PM   #14
Vinsanity
Vinsanity's Avatar
Drives: Yaris
Nice woofer. Slappin real hard
Vinsanity is offline   Reply With Quote
Old 02-28-2009, 03:16 AM   #15
fuji
fuji's Avatar
As far as the components are concerned, I will be running Zapco CK16.2. Instead of using the crossover, I will be using 2 different amps, a dc200.2 for the tweeters and a dc350.2 for the woofers. I will run the system completely active. After I have everything set up, I will use the Zapco tuning software and for the Yaris tune out all the peaks and dips in frequency response. It will take some time but I think it is worth it. All the speaker, power, and signal cables are KnuKoncepts.
Old 02-28-2009, 01:42 PM   #16
06vitzRS
Drives: 06 Yaris HB
Where did you get that ground cable from? I want one.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 02-28-2009, 03:16 PM   #17
fuji
fuji's Avatar
Also from Knukoncepts. It is the 0 gauge ulraflex with 0 gauge ring terminal. It is pretty flexible. The 4 and 8 gauge are unreal. There is a screw to secure it. I then added a bit of heat shrink to seal it. The battery terminal is also from Knukoncepts
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Which way to face subwoofer? Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 22 11-02-2008 09:02 AM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
Subwoofer enclosure Kitt Central and South America 14 08-16-2007 02:16 PM
Kenwood KSC-SW1 Powered Subwoofer seriousfun In Car Entertainment + Electronics (audio / video / alarm) 11 04-02-2007 02:44 PM
