Old 07-24-2006, 05:54 PM   #1
Toddhata
Toddhata's Avatar
Drives: 07 Yaris Liftback, 00 Boxster
Send a message via AIM to Toddhata Send a message via Yahoo to Toddhata
Fumoto Oil Drain Valve
Anyone try this on the Yaris yet?
link
Toddhata is offline   Reply With Quote
Old 07-24-2006, 06:20 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Sounds kool at least....but no...have not tried it.
Old 07-24-2006, 06:25 PM   #3
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
no, but i might.... hmm, of course it would really suck if something whacked it going down the road and all your oil drained out.... of course, i'd hate to have something get up there and whack it anyway
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-24-2006, 06:32 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
I have seen them before used on lots of the other message boards I belong to, all with great results. I plan on getting one soon, as I am already coming up on 3k miles.
Old 07-24-2006, 06:33 PM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
They work good for a while but one on my work truck leaks after only 2 summers...
Old 07-24-2006, 07:06 PM   #6
Chris07LB
Chris07LB's Avatar
Crap, thats exactly what I didnt want to hear. Thats is actually the first negative I have read on the valves though.
Im still going to give it a go, if anything, I can always switch back.
Old 07-24-2006, 07:13 PM   #7
Toddhata
Toddhata's Avatar
I found some old discount codes on other forums, but they're expired, so I emailed the company to see about getting a new code. I'll post it if they give me one.
Old 07-24-2006, 07:15 PM   #8
Chris07LB
Chris07LB's Avatar
Thanks Todd.. Ill hold off on ordering until then.
Old 07-24-2006, 07:16 PM   #9
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
FRAM also has a similar drain called SureDrain. Although, I cannot find a link other then the installation guide. Kinda weird. I do see a bunch of car forums that talk about it tho. This is the only place I can find it for sale. The FRAM plug doesnt stick out as much when not being used.
http://rustysoffroad.com/Merchant2/m...egory_Code=RED
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 07-24-2006, 07:28 PM   #10
Chris07LB
Chris07LB's Avatar
Thanks for sharing that.. it looks like a very simple idea, and its much less then the Fumoto Valve mentioned above.
Here's a pic of the FRAM, for the lazies..
Old 07-24-2006, 10:54 PM   #11
eight_heads
i think the fram one looks a little better
'07 Yaris Liftback
Old 07-25-2006, 11:41 AM   #12
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Fumoto Engineering of America offers a LIFE TIME WARRANTY on its product, against faulty workmanship and/or material to the original purchaser (with proof of purchase). For any defective product, Fumoto Engineering of America will replace the product at no charge. Fumoto Engineering of America will also indemnify any consequencial damages to the engine/vehicle which are directly caused by the defective product. This warranty does not cover any damages due to misuse, abuse, negligence or accident. This warranty is valid only in the United States and Canada.
tomjasz is offline   Reply With Quote
Old 07-25-2006, 11:47 AM   #13
tomjasz
tomjasz's Avatar
http://autospeed.drive.com.au/cms/A_2029/article.html
Old 07-25-2006, 02:01 PM   #14
Packy
Drives: Honda Fit Sport
The Fumoto valve rocks! We have one on our Subaru and it makes oil chages that much faster and cleaner. I'd recommend it. To the person who had a leaking one, was it leaking from the crush washer or the valve itself?
Packy is offline   Reply With Quote
Old 07-25-2006, 02:42 PM   #15
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
The valve itself
It's only a small leak (couple drops a day) but at any time you look at the valve you can see a drop of oil hanging from it...
My guess it there was grit or something in the pan that damaged the seat of the valve when it was opened and closed again.
From what I understand they are a teflon or nylon sealed ball valve and the leak is most likely between the ball and the nylon seal...
We have one on the F150, and 3 other on other cars. So far only the F-150 leaks but it's also used every 2 months.
Old 02-15-2007, 10:33 PM   #16
"G"
Drives: 2007 Yaris Hatch
These are gay, your better off spending your $ on a magnetic drain plug.
"G" is offline   Reply With Quote
Old 02-16-2007, 01:32 AM   #17
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Thats my thought too. I'll start a new thread because I'm curious what others think of the magnetic plugs.
PetersRedYaris is offline   Reply With Quote
Old 02-16-2007, 07:00 AM   #18
Chris07LB
Chris07LB's Avatar
Comparing apples to oranges..
Its an easy way to drain your oil for a quicker and less mess.
A magnetic plug is always a good idea, but thats not what we were talking about here.
A related thread to "What's Next for the Yaris" (Ethanol) Goose General Yaris / Vitz Discussion 15 06-05-2007 05:15 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
oil changes on your Yaris asa805 DIY / Maintenance / Service 34 07-27-2006 12:41 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
