Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT Join Date: Jun 2009
1NR-FE Performance & Tuning
Well, this is my first post here, so hello everyone!
![]() I own a Yaris with the new 1NR-FE engine. I would like to find out what are the tuning options that we, owners of a 1NR-FE engine, have. It seems to me that not even an air intake has been made for this engine yet, so I'm posting here in case some of you have got some lucky find. I'm pretty sure I am not the only one having this engine here and interested in tuning options, so let's post here everything we've got.
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
NEW ENGINE means NO parts yet......
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
what is the displacement?
TRIM HUNTER
1.3 1NRFE
Who said Yaris was slow?
Unless this new engine gets to the US in any other Toyota, then probably will never have any aftermarket support...
I'm lucky that the yaris TS shares the engine with the US scion xD and Corolla |
AKA Samurai Racer
Welcome bro !! post a pic of what the engine bay looks like, maybe there are similarities. We have got those engines in our new corolla's its a 73kw 1300cc if i remember correctly , a dual VVT 1300.
you might find , things like the motor pullies are the same , but that would be about it for the engine , as it is orientated 180degrees too the 1NZ-FE and the 2NZ-FE.but all the suspension compenents will be the same .
#8 | |
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
βρε συ... αυτό το μοτέρ δεν το έχουν στην αμερική.
ούτε η blitz δεν το ξέρει. στο λέω γιατί ρώτησα για κάτι. |
Yaris Lunatic!
Guys, I know it is a new engine and this means there are no parts yet.
However, I started this thread because I am pretty sure that there might be similarities with older engines in some parts. The member Kongo-Otto has posted some engine bay pics here: http://www.yarisworld.com/forums/sho...3&postcount=64 Thanks ![]() @ yaris_2sz: Γεια σου φίλε μου! Το γνωρίζω ρε συ ότι δεν κυκλοφορεί εκεί, αλλά ψάχνω από δω κι από κει για να βρω πράγματα. Δεν είναι ότι καίγομαι αυτή τη στιγμή να το βελτιώσω, απλώς μου αρέσει να ασχολούμαι και δεν βρίσκω τίποτα. Anyway, τα λέμε στο ελληνικό φόρουμ ;) |
![]() ![]() Drives: Yaris Sol 1.3 dual VVTi 101hp Join Date: Apr 2009
I've the same engine (from Piedmont - italy)
it works very well & push enough, even if I miss a lot the "kick in the ass" typical of turbo charged engines anyway the car runs really smooth & comfortable to drive even if it has a sort of nightmare clutch/gear combination (6 speed)... expecially when cold from 1st to 2nd gear is a disaster, you can't shift at too high ranges (already changed with Redline MT-90) if you need some specific info feel free to ask my actual mods are: 1. ZX1 anti-attrite (everywhere) 2. Redline MT-90 gear oil (a bit better) 3. UltraRacing 19mm rear sway bar... thx Garm ![]() 4. K&N Air panel (no. 33-2211) planning mods: 1. new & lighter rims 2. new rotors/pads set 3. I'd like to try crank pulley but I'm not sure it will fit... bye, davide
Yaris Sol 1.33 dual VVTi model 09 - 5dr 1. full ZX1 additive treatment: oil + cooler + fuel 2. NB treatment: motor oil 3. K&N panel air filter (part num. 33-2211) 4. Fuchs Silkolene Pro SRG 75 gear oil (the best!) 5. UltraRacing 19mm rear sway bar |
Yaris Lunatic!
Thanks for helping and posting your mods, suiller.
![]() Drives: 09' yaris 1.33 Join Date: Feb 2010
Any news and mods for that engine?
#14 |
I'm looking for a "serious" intake... something like Fujita
![]() this should fit
#15 |
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
This cant fit because the 1NR-FE has the exhaust header at the front and the intake manifold in the back. Something new has to be developed for this engine.
#16 | |
anyway I studied the situation again and I was thinking also to leave untouched the original airbox, just (as I did) replace the OEM filter with the K&N (33-2211 model) and removing the original arm... as you know the original arm seems too thin & above all it doesn't turn close to the floor, so it sucks (almost) warm air the idea was to remove the OEM arm & installing something like RamII (80mm section) downturing it close to the floor near the right fog lamp do you have some other ideas??
#17 | |
#18 |
so you think is useless to enlarge arm section?
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| New shift knobs available from TWM Performance! | TWM Performance | TWM Performance | 3 | 06-25-2009 04:24 PM |
| Anyone need ECU tuning done on American Vehicles? | Nexus1155 | New England | 5 | 06-10-2009 07:15 PM |
| Save $20 on every TWM Performance short shifter/shift knob combo! | TWM Performance | TWM Performance | 4 | 05-29-2009 04:36 PM |
| Yaris Performance Specs | neohalo | Performance Modifications | 22 | 06-24-2007 08:46 PM |
