![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Spark Plug Gap
For you boosted guys, I see that Denso makes the IK22 with a .031 gap.
I can get the brk7eix-11 that come gapped to the yaris spec'd .044. Is there any problem running the Denso? Reason I ask is because I have found a source for the IK22's for the same price as the NGK's. Thanks! |
^ Just make sure you are running the proper heat range.
Mine are gapped to .028, gap depends on the tune, boost etc.
Well, my application is blitz sc only.
So Heat Range 7 is what I gathered from here. I just need to know if the stock gap should be used or if the IK22 gap is ok. So you are saying the smaller the gap for the more boosted and tuned you are? Thanks! Last edited by sleey0; 09-21-2010 at 01:11 AM. |
I just know my car likes it that way. I can't really explain the science, but I'm sure my tuner could.
Rollerskate
The reason spark plug work better with a small gap under high boost is because it is harder to spark the spark plug with a big gap under high boost but under n/a it's easier to spark with a big gap
cdy - I am not yet boosted but I am getting my ducks in a row, so-to-speak. I want to make sure I have everything I need before hand. I have been told many times that ppl around here thought they had everything and then they needed something at the last minute. I am doing the best I can at covering all my bases.
1.5ty - Thank you for that info! Thanks, guys. I will go ahead and order the IK22's. Last question. Are the 1ZZ injectors the max recommended? Or can I find ones with a little bit more cc/hr? Thanks to all. VERY helpful and I love this forum:D |
| Spark Plug | ubospawis | Middle East | 11 | 09-01-2010 08:55 AM |
| Do we need to regap our spark plug? | marcus | DIY / Maintenance / Service | 2 | 08-31-2010 10:53 PM |
| spark plug gap | Hard_Yaris | DIY / Maintenance / Service | 2 | 06-10-2010 05:23 PM |
| Plug Gap | slvryaris | DIY / Maintenance / Service | 1 | 12-23-2008 10:02 PM |
| spark plug | 33lam | Performance Modifications | 25 | 12-23-2008 04:40 PM |
