![]() Drives: '07 Hatchback Join Date: Oct 2008
Help! I get in my car this morning,turn the key and nothing. Not a click, moan or anything. Headlights, stereo and A/C all work fine. The car has been registering 13.9, 14.0 consistently on my scan guage for the last couple of months and the battery is only 1 1/2 years old. Car is 2007 Hatchback. Any Ideas? Charging the battery didn't work either
Go get a neighbor to try to jump start your car. If nothing happens still theres your answer. Its not the battery. Its either your starter or ignition switch
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
best thing to do is try and get it to the dealer.....
other than that any mods that could alter electrical components in the car? oh and welcome to Yarisworld unfortunately this isn't the right section to ask this but hopefully a moderator can help you out by moving it to the proper forum....this forum is for the site itself not the car :) |
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
Is it an automatic?
If so, try starting it in neutral position (parking brake on to hold the car still.) |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
Keep in mind that the ignition does not start cars like they used to. It simply sends a signal to the ECU to start it (hence it automatically cranking until its started, etc).
The fact that their is no click at all and everything else gets power it is probably not the battery. The best place to check would be the fuses. Other then that a connection is probably bad. |
fuse box diagram
Thanks, I think its a fuse problem but I can't find a diagram of what fuse does what
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
If it is a manual transmission, could the clutch switch be bad?
When I put in winter car mats over the carpeted floor mats, I found that the winter mat sometimes caused the clutch pedal to not go all the way down. Thus, the car wouldn't click but just give me dash lights, etc. So, I had to pull the mat back toward the seat a little for it to work. I'm going to have to trim the mat a little or possibly remove the carpeted floor mats underneath. Just a thought. |
#8 | |
Wiring diagram should help: http://www.etimago.com/yaris/repairmanual/EWD.pdf |
Lil Monsta
Drives: Super White Yaris 08 Sedan Join Date: Dec 2008
try to main relay fuse.
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
fuse sounds likely to me...
the manual tells you what fuse does what
Sold the yaris... rocking an 89 vw cabriolet now :) |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
we had a '03 MATRIX and '99 COROLLA do that . Especially first thing in morning or when driven awhile and then restart after sitting for a bit . They did start overtime . Thankfully we've always had 2 cars . Makes me wonder if it's an fuel system thing ( fuel pump , injectors , computer , etc. ) . Such as flooding or no fuel .
Lil Monsta
i had exact problem, it was relay fuse.
#13 | |
Drives: Yaris 1.3 -08 Join Date: Sep 2009
My wife cleaned the mats in her car yesterday and this morning her car wouldn't start. After reading this I just went out to the car, moved the left mat to the left side and the right mat to the right side (yes, the mats where put the wrong way). The mat had been a long way up under the pedals. After that the car started without problem. |
#14 | |
Drives: Yaris 2DR LB 07, MT, Abs. Red Join Date: Feb 2009
Reluctantly Crouched...
Wow...that's a long time for your car not to start (11/2008) :)
Heres another "my car wont start" possibility. One cold morning when it was seven years old my ECHO wouldnt start. I figured "Seven years...bad battery." Bought a new one and it still wouldnt start. The problem? ICE got into the switch at the bottom of the clutch pedal travel! Merde!
![]() Drives: 2007 toyota yaris hatchback Join Date: Sep 2010
I'm having this problem in my 2007 hatchback... I replaced the started relay and still no change. what am i doing wrong? there's nothing blocking the clutch which fuse could it be?
thanks |
Only Happy When it Rains
it could be a ton of other things, what happens when you turn the key?
Colin Chapman disciple |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| Yaris TS 1.8L History and Specs | CASTREX | Yaris TS Talk | 52 | 10-27-2009 06:06 PM |
| Interesting Info on the Yaris from AU | mikeukrainetz | General Yaris / Vitz Discussion | 3 | 11-24-2006 10:18 PM |
