Old 07-15-2011, 07:54 PM   #1
auxmike
auxmike's Avatar
Can the Yaris run on E85? Anybody try it?
The local Valero gas station by me sells E85 for like a buck cheaper than "real" gas.
Can the Yaris run corn juice????
Old 07-15-2011, 08:22 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
E85 is costs less, but cars running it get FEWER MPG than regular gas...
Old 07-15-2011, 08:38 PM   #3
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
pretty sure you have to have a "flex fuel" vehicle to run it but as previously stated your mileage will not be the same. it all evens out in the end.
if you have a vehicle that is made for it, I think it does better but it has to be made to run the stuff.
not 100% but that is what I think
Old 07-15-2011, 09:01 PM   #4
auxmike
auxmike's Avatar
Sounds like a waste of corn/food!
I was also curious to see if the yaris fuel system could handle it without being damaged.
Old 07-15-2011, 09:23 PM   #5
This is a good Q and A on E85. The main reason you "can't" use it in the Yaris is that the ECM isn't programmed to deal with the difference in target AFR required to use it. Also, it's not quite as economical as you might think, since if you added a piggyback (and larger injectors) to tune for it, you would use about 30% more E85 fuel.
http://www.howstuffinmycarworks.com/...E85_fuel_.html
Old 07-18-2011, 11:21 PM   #6
detroiter
detroiter's Avatar
If I recall right, the injectors cannot handle the e85 and also since there is
so much alcohol content in that stuff, it'll eat/rot out your fuel lines like no other.
Old 07-18-2011, 11:27 PM   #7
That turns out to be a fable. Vehicles built since the early 80's use rubber and plastics that are not susceptible to alcohol. The biggest concern with E85 is its ability to absorb water and hence corrode ferrous metal parts.
Old 06-23-2012, 08:42 PM   #8
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Nope. Modern flex fuel car fuel lines are different composition than normal E10 fuel lines.
Old 06-24-2012, 09:53 PM   #9
mr_miles
Drives: 2013 Yaris
i recently saw a gas station that stated their premium had no ethanol in it...my tank was full, else i would have filled up with it and seen what the difference was.
Old 06-25-2012, 06:38 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
why do you need premium?
Old 07-19-2011, 05:19 AM   #11
bronsin
bronsin's Avatar
Enthanal use should be shunned by all consumers! Dont encourage these a holes by buying their crap!
Old 03-17-2012, 03:13 AM   #12
nookandcrannycar
I've driven my Yaris in 45 states and in some states the octane rating for the standard grade unleaded is 86 instead of 87. My car has never run differently to any noticeable degree after such fill ups and I've never had any fuel related part fail. However, re 85 octane gas, the previous posters on this thread could easily be correct.
Old 06-22-2012, 06:42 AM   #13
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's already blended in with your gas, and has been for a long time: http://en.wikipedia.org/wiki/Gasoline#United_States
It's very hard to come up with something that can rival the energy density of petroleum based fuels. The fact that they can get as close as 70% from fermenting corn is pretty impressive.
Old 06-22-2012, 05:18 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
no it isn't. Destroying a food source to use as fuel when a much better fuel is already in use is really dumb. It is one of the factors that is driving food prices up world wide. If we wanted to use alternative fuels, diesel and people that convert them to using old vegetable oil as fuel, now that is impressive.
Adding ethanol to gas makes it both more expensive and get worse gas mileage. It is a total disaster to everyone that does not sell corn for profit.
Colin Chapman disciple
Old 03-17-2012, 11:12 AM   #15
^ Hes not talking about 85 octane, but E85, i.e. a fuel blend that is 85% ethanol from corn or other biomass...
It's interesting to note that a lot of tuners seem to use E85 as a cheap alternative to race gas, since the octane rating is comparatively high... and they're not too concerned about mileage :D
Old 06-22-2012, 10:39 PM   #16
nookandcrannycar
Oops.....I feel like a male version of Gilda Radner's Emily Litella on that one....I TRY to NEVER ASSUME......because look what happens when one does!
Old 06-22-2012, 03:40 AM   #17
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
so i guess no one hasn't used E85 yet huh?
any update OP?
this might help http://www.change2e85.com/servlet/Page?template=Myths
i would do the conversion... if i had money.. hehe..
http://e85prices.com/california.html at the lower right corner of the page, there's a calculator.. unless someone has done actual mpg calcs on their yaris, we can only assume, that even with a 10-15% reduction in mpg, E85 is still a good deal..
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 06-22-2012, 05:33 PM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
E85 on a boosted 1nz would be
The only way to go. Yes, your target AFR is richer on E85, but you can make a lot more power per psi of boost simply because E85 has a much higher octane rating than even "premium" fuel, which allows you to gain back those timing retards you had to do on regular pump gas. Long story short, boost and E85 are a GREAT combo.
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
I think I was being made fun of for driving a yaris (or my yaris) last night.....hehe PETERPOOP Off-topic / Other Cars / Everything else Discussions 21 05-16-2010 03:19 PM
New Yaris 5 DR HB arriving April 5, 2010 mkorejwo New YARIS Purchase Forum 6 04-06-2010 11:39 PM
