Where is Oahu?
Since brian and peterpoop did the DIY for these projectors, I'll post the pics. I'd like to thank Garm at Microimage for bringing in awesome products! The only problem I had was the alignment for the headlights-When I had the locking nut for the projector in...the headlight cutoff was off. The locking nut was removed and replaced with a rubber washer. I then eyeballed the cutoffs for the headlights by shining them at a wall. I'm guessing that I had this problem because my car is an 09
***One tip with baking the headlights, put wood under the headlight so you won't melt the housing*** On to the pics!![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Picture Update 2/1/10-Audi Style Led Lights: It was hard for me to take a clear shot of my headlight because of the leds' brightness. Enjoy ![]() ![]() ![]() Picture Update 2/23/10-Audi Style Led Lights: Here's a clear picture of the lights. ![]() UPDATE 7/8/10-More pics ![]()
808_Yaris Air Runner Thread:http://www.yarisworld.com/forums/sho...655#post329655 808_Yaris Air Runner Video:http://www.youtube.com/watch?v=fUkqox5d5No 808_Yaris Retrofit Projector Pictures:http://www.yarisworld.com/forums/showthread.php?t=22461 Last edited by 808_Yaris; 07-08-2010 at 01:49 PM. |
looking good! nice surprise to see them at the meet today! lol
oooh perfect a 09 MM, could i see some shots further away of the car? Looking good tho.
やりすぎだ~
More of 808_Yaris' car with projectors can been seen in this thread.
![]() Drives: Yaris sedan Join Date: Aug 2009
Hey Bro, i have a yaris sedan 1.5 but i would like to know that making that implement you had problems with the horizontal leven in the retrofit?
I hope do the same for me sedan but the nivelation is my issue. Best wishes Santiago Ponce |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
The retrofit looks great! I can't wait until I get a pair!
Where is Oahu?
I'll post the more pictures soon!
808_Yaris Air Runner Thread:http://www.yarisworld.com/forums/sho...655#post329655 808_Yaris Air Runner Video:http://www.youtube.com/watch?v=fUkqox5d5No 808_Yaris Retrofit Projector Pictures:http://www.yarisworld.com/forums/showthread.php?t=22461 |
Where is Oahu?
horizontal level was off when i put everything on correctly...instead of using the locking washer(i think that what you call it, it's a ring with three prongs that's supposed to lock the headlights into place), i bought a rubber washer at home depot (size is inch and a half) and used that in place of the locking washer. From there, i guided the projectors so the cutoff was level, and tied everything up.
Curious if you had the same issue as Peter with the projector not fitting in the hole and having to dremel it out a bit....
I plan on doing this relatively soon |
Where is Oahu?
Yes i had the same issue as peter. I dremeled the hole out enough to fit the projectors. I'm guessing this goes for all liftbacks, sedans shouldn't be a problem. good luck with your retrofit!
Thanks for the heads up!
Your car looks really nice, man |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
This should be on the DIY
can u post a pic of the cut off ??
find Brian's thread he has pics of the cutoff, it's very nice
The Beautification of Car
Nice projectors if only one day I will be brave enough. But I'm suprised you didn't paint the housing black around the headlight.
possible future sale, but not right now. I only have one set left in stock by the way.
Yes, this should fit into any car that uses an H4 bulb. (note that some cars, like the liftback but not the sedan, need to have the hole opened a little)
thanks no problem, i can only use the dremel to make it fit. I will possible buy two in the future one for me one for my dad versa.
| To put on PnP HID kit without retrofit, Yes or No? | mr.white_hb | Cosmetic Modifications (Exterior/Interior) | 3 | 09-20-2009 08:43 PM |
| Should I blackout my housings with my retrofit projectors? Or no? | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 26 | 09-08-2009 03:24 AM |
| Fx Projector Retrofit on tca4's car | drknss99 | DIY / Maintenance / Service | 18 | 09-14-2007 09:39 PM |
| FS TL PROJECTORS | sam07yaris | Items for Sale by private party | 3 | 07-06-2007 04:18 PM |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
