Old 10-06-2010, 11:43 PM   #1
walt101786
Drives: 07 Toyota Yaris Hatch-Back
maintainace lights on
hey everyone, well recently my maintance light came on...when it came on, i would just change my motor oil, but see the problem is that the light is still on...does this mean that i have to change my transmission oil as well?? cus i have about 44k on my yaris H/B...so plz tell me what need to do
walt101786 is offline   Reply With Quote
Old 10-07-2010, 12:50 AM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
You need to manually reset the light.
1. Set your dash display to trip meter A.
2. Turn your key off.
3. Hold down the trip meter reset button as you turn the key back on. Continue to hold the reset button down. You should see a series of diminishing dashes where the odo and trip meter display is. When they all disappear the maintenance meter is reset. You can then release the button.
That should do it.
-The Fitful One
Old 10-08-2010, 09:55 PM   #3
walt101786
hey i did what u had suggested, man it sure do it lol....got another question though, since im about to hit 45k on my H/B....should i start considering changing my transmisson oil? cus i already changed my reg. oil like 500 miles ago.....
Old 10-08-2010, 10:05 PM   #4
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Walt,
Do you have a manual or automatic?
-The Fitful One
Old 10-09-2010, 03:38 AM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i'll toss my question in with his, does dirty trans fluid hurt fe?
Colin Chapman disciple
Old 10-09-2010, 05:22 PM   #6
walt101786
well, i am having an auto...so in which case i heard that normally, trans oil should be changed like every 30k-50k so should i consider of changing it soon? and which trans oil i should use...cus at a local pepboys told me that i need the factory ones...but in autozone told me i could use the multi-car one...so yea
Old 10-10-2010, 11:08 AM   #7
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Walt,
According to Toyota the WS ATF doesn't need to be changed. I personally am going to service mine regularly because I plan on keeping it for a long time. If you plan on keeping yours beyond 100k or I would service it. Toyota is the only official source of WS but other fluids are recommended for it including Valvoline Max Life, Amsoil, Redline, and Amalie.
Why?,
To address your question transmission oil should really only get "dirty" from wear particles and oxidation of the fluid itself (although other sources of dirt or water are possible). This would be most detrimental in that it could cause accelerated wear, but in severe cases oxidation and the subsequent thickening of the fluid could affect FE (though probably very little). I would worry mostly about the increased wear issue, however. If I owned a manual Yaris I would change the gear oil in the Yaris every 30k with a high quality fluid.
-The Fitful One
Old 10-10-2010, 11:46 AM   #8
c-dub
Drives: 2008 yaris
what fluid would you use? would you go synthetic?
c-dub is offline   Reply With Quote
Old 10-12-2010, 11:19 PM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Personally, yes I would use a synthetic lube. I have always used synthetic lubes in my MTs-mostly due to ease of shifting in extreme cold. I would use either Amsoil MTG or Redline MT-90 in my Yaris if I had a MT.
-The Fitful One
Old 10-12-2010, 11:39 PM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
Castrol Import fluid would work fine... if you want to go synthetic just about any of them will work. Just look on the back of the bottle and make sure it says it meets Toyota type fluid requirements.
I have changed the fluid in my; 06 Scion xB, 08 Yaris and 01 Rav4 with the Castrol import and a new filter and gasket with zero problems
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 10:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 08:54 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 01:34 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 10:24 AM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 02:45 AM
