![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Best replacement tire size for stock rims?
Kind of unsure what tire size to get because some say with the stock 185/60's that the speedometer is incorrect, but other sizes show to be incorrect as well. What would be the best replacement size for the stock 15" rims? I'm running Tein springs.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
bump
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I'd be surprised if the speedo was off with 185/60's since that is what Toyota puts on stock. Speedometers are factory set based on stock diameters.
Either way, the speedo change is negligible with only slight size variations. It's not something to concern yourself with. I personally prefer 195/60's. They offer a fuller look that slightly extends beyond the wheel cover. The 185's look too thin and undersized IMO with the wheel covers protruding beyond them - not a great look. I've clocked my speed with a GPS and the speedo was accurate even with 195's. Plus, performance/stability naturally improves with the wider tread. EDIT: Forgot you said you were lowered. In this case, perhaps a 195/55 would be a better choice since you have less wheel gap.
My speedo was off with the stock 185/60/15's, but is dead on with 205/50/16's.
With Tein springs, I would recommend 205/50/15's. |
Well the 14" came stock in Canada as far as I know and there's no changes in the speedo setting between our 15" Yarii's and Canadas 14" ones.
So what would be the better choice then..195/55 or a 205/50? Are they going to bulge out too much since the rims are only 5.5? And how about sidewall flex, will that be a problem since they will stick out more?
205's will fit safely on 5.5" rim.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Why don't test your speedomoter? Use the highway mile markes and compare the difference for 10 miles between the actual miles and your odometer. Assuming the speedometer and the odometer are in sync, you should know how accurate your car is. My stock set up is very accurate.
Making a decision without following it with an action is still a fantasy. |
#8 | |
As far as tire flex, I wouldn't worry about it with 195 or 205's. Tire flex is due more to sidewall height than width. Really, you'll have more grip and stability in the corners with these wider options. |
![]() ![]() Drives: Black XA not yaris but close Join Date: Jun 2009
Im going back to the 185/60 15s, I run stock steelies. I had replaced all four with 195/65 15s and it was bad. Mainly the 65 part, way too much sidewall lots of flex. The increased overall diameter\weight means your just pissing torque away too. It was noticable. The guy at discount tire company suggested them, i said okay, now I know better. Wider is ok, taller's not. I'll go wider when I get some lighter rims to make up the difference in unsprung wieght.
I order tires from tiresonline.com and install them myself with a harbor frieght tire changer and bubble balancer. First one was a beating, now it takes about 10 min a tire. |
#10 | |
However, you don't need to go back to 185's. 195's are very good, just keep the aspect ratio to 60 or below. |
Thanks for the help guys. So I'm leaning towards 195-55's. Would the 205-50-15
give me any trouble since I'm riding low with the Teins?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
^ Nope. And I'd go for 205/50's unless you're running these in the snow. Then I'd recommend the 185's.
Yeah i'm going to be running these in the snow. Not really feeling the 185s though, they charge alot more than they do for 195's, atleast here they do anyway
#14 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
im running 195/55/15 but i have my car lowered
#15 |
I've ran four different sizes on 15's so far (205/50, 195/55, 195/50, 185/60) and I while I loved the 205/50 and 195/55 or 50's in the summer, they sucked in any sort of snow accumulation.
But if you're going for price only, 195/50's are usually cheaper than 195/55's since it's a common size for the Honda guys. |
| what tire size fits best for 15x6 rims? | savister | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 04-26-2010 09:37 PM |
| Tire Size and FE question | GMKing | Fuel Economy Forum | 8 | 09-01-2009 10:20 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
