Old 10-30-2010, 08:26 PM   #1
biggerman40
Drives: 2010 Yaris
Side mirrors
We just bought my son a 2010 yaris but did not get the power package is there a way to change the side mirrors w/o power to mirrors w/ power.
biggerman40 is offline   Reply With Quote
Old 11-15-2010, 11:04 PM   #2
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
I don't know about the 2010, but I am guessing it may also have the wiring harness for power mirrors already to go. I have a 2008 LB and it had all the wires that I needed. I bought a switch off ebay from a 2003 xA, after checking with the wiring diagram and verifying that it was compatible. I plugged it into the harness. Then I bought 2 TYC power mirrors from Amazon. Removed the door panel (using previous DIY), removed mirrors (using previous DIY) added new mirrors plugged into pre-run harness checked their operation and bolted it back together. Viola, power mirrors for under $100.
In the pics below, you can see that you remove the storage box on the dash (squeeze the sides and pull it out). Then pop out the mirror switch blank from the back by squeezing on the tabs and pushing. You should be able to locate the 10pin connector almost right behind the blank. Plug in your switch, mount your mirrors on your door and plug them in and your done. Took me all of 30 minutes.
az_saguaro is offline   Reply With Quote
Old 02-27-2011, 01:12 PM   #3
rapev-8
Drives: toyota
any update? i have a 2010 also, is it all pre-wired?
rapev-8 is offline   Reply With Quote
Old 02-27-2011, 01:19 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
IDK
Old 02-27-2011, 01:25 PM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
But I know someone who might, were is CTscott?? Lol he can answer this with no problem,
Old 02-27-2011, 02:22 PM   #6
I believe that they are all pre-wired. A while back someone asked if their car was pre-wired for power locks and in the process of checking for that (which they are not), we found that the wire was in place in the door for the power mirrors.
Old 02-27-2011, 04:08 PM   #7
MadMax
MadMax's Avatar
Do the TYC powered mirrors fold like the stock ones?
Cheers! M2
Unlinking heated side mirrors / rear defrost Alezius DIY / Maintenance / Service 9 11-03-2010 02:29 PM
auto folding side mirrors shameer_k Cosmetic Modifications (Exterior/Interior) 9 04-21-2010 04:05 PM
The screws underneat the side view mirrors... Sodium Duck Cosmetic Modifications (Exterior/Interior) 16 03-25-2009 09:04 AM
adjusting the side mirrors??? brpnagger General Yaris / Vitz Discussion 4 07-02-2007 04:07 AM
side mirrors got615 Cosmetic Modifications (Exterior/Interior) 0 05-09-2006 02:28 PM
