Old 07-24-2010, 11:43 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
BOV... recirculating or vent to atmosphere?
I've read that while using a MAF for airflow metering, you should be using a recirculating BOV. If that's the case, do you want the MAF to be on the intake or discharge of the turbo?
I can see a venting BOV to be a problem if the MAF is before the turbo as you'd be expelling metered air and would run crazy rich when you let off the throttle.
Those with turbos, what's your setup?
Old 07-24-2010, 02:35 PM   #2
I have the Turbonetics kit in my tC, it has a recirculationg BOV. I think many bolt-on kits work that way for the reasons you mention.
on the Yaris, my BOV is installed right on the intercooler.
Old 11-06-2010, 02:39 AM   #3
jenfre
jenfre's Avatar
Drives: Yaris RS 2009 5DR
but on your yaris is the bov exhaust air in the piping ? or atmospheric ?
Megan Racing Coilovers - HID 6000K - Fog Light 12 000K Blue - 50/70/90 Tinted WINDOWS - Short Shifter TWM - Rota Sliptream 16x7 Direzza StarSpec 205/50r16 - Injen CAI - R1 Concept Slotted Rotors - Carbotech Brake Pads XP8 - SS Lines - Sparco Steering Wheel - 23MM Rear Sway Bar - Ultra Racing rear, under and fender brace - Borla Axelback
jenfre is offline   Reply With Quote
Old 11-06-2010, 04:09 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
If you install a recirculating BOV, the discharge end of the BOV should lead back to the intake - anywhere between the MAF and inlet of the turbo. T
Old 11-06-2010, 12:55 PM   #5
My Yaris BOV vents to atmosphere.
Old 11-06-2010, 01:20 PM   #6
cdydjded
Drives: Yaris LB Turbo
Mine also vents to the atmosphere....
Old 11-06-2010, 06:24 PM   #7
Bluevitz-rs
But Cali's Yaris is running a MAP sensor. Right?
Old 11-06-2010, 11:30 PM   #8
cdydjded
Should be since he is not using the factory ECU & is using an AEM EMS...
Old 11-07-2010, 01:33 AM   #9
^ correct. but it was also vented to atmosphere when I first ran the turbo at 8 psi on the ECU.
Old 11-07-2010, 10:09 AM   #10
Bluevitz-rs
And you didn't have any stalling issues from the system going rich when you let off the throttle?
Old 11-07-2010, 10:26 AM   #11
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I vent to atmosphere. My BOV is adjusted a little tight. Once in a while I will dye out if I stab the gas in first and then shift to neutral and let idle. This will cause that very rich idle condition. But during all other normal shifting and full throttle driving its just fine. I was thinking of recirculating just to see how the car reacts.
pimp my yaris is offline   Reply With Quote
Old 11-07-2010, 11:54 AM   #12
I had no problems at all.
air vent control nazier DIY / Maintenance / Service 0 07-05-2010 04:58 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 09:36 AM
FS: NIB AutoventShade In-Channel Vent Visors + Like NIB TYC Tail Lights. IsLNdbOi Items for Sale by private party 14 12-11-2008 03:27 PM
