![]() Drives: 07' Sedan Join Date: Apr 2009
Does 185/70R14 fit on Sedan?
Has anybody put 185/70R14 tires on a stock Yaris Sedan? I'm looking at snow tires and I am reluctant to go to the 175/65R14 that TireRack recommends because of the reduced diameter (and lower ground clearance). I currently have stock 15" tires on the car. TireRack is reluctant to sell me the 185/70R14 due to the increased diameter from my current tire and fitment would become my responsibility if I don't go with their recommended tire. The rim would be 6" ET45. Any Advice? Thanks alot!
Current tire is: 23.8" Diameter Tire Rack recommended: 23.3" Diameter The one I'm thinking is 24.2" Diameter |
Once again I must reserve my comments about tireack.
Yes, 185/70/14's will fit without any worries whatsoever. |
Mr. 155 and climbing
so you are getting 14" wheels then right?
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
SailDesign makes a good point about installing narrower tyres for winter driving.
175/70/14 = 23.7" diameter 185/70/14 = 24.3" diameter Both tyre sizes will work well. In fact, these diameters are equivalent to OEM tyre sizes: 175/65/14 = 23.0 185/60/15 = 23.7 195/50/16 = 23.7 205/45/17 = 24.3 TRD Option 215/35/18 = 23.9 With stock suspension, you may safely fit many tyres from 23.0 to 24.3, +/-3%. |
I would really like the 175/70R14 but they don't have the particular tire in that size. That size really limits your selection.
Based on TireRack's actual measurements, i can go .5 inches smaller diameter with the 175/65R14 or .4 inches larger with the 185/70R14 Sooo... Smaller diameter with lower clearance and possibly more grip... or larger diameter with more clearance with less grip.... Last edited by bikeshox; 10-29-2010 at 02:23 PM. |
What tyre are you looking for?
#8 | |
The General Altimax has pretty good reviews and its cheap.
I practically ran wagon wheels on my tercel and you couldn't stop it in any type of snow
So the consensus seems to be smaller wheels, less width, of my two choices.
I wouldn't go too narrow - 175 is fine, but don't be tempted to go w-i-d-e to "float" over the snow - you need to get weight onto the tread to make contact for traction and stopping. Extremely narrow tires, like rally snow tires, are very little use on bare ploughed pavement.
The difference between a 175mm and 185mm tyre is really going to be negligible in the snow. I wouldn't worry about it.
Because your tyre of choice (and it's a good one) is only available in 185/70/14, I'd go with this size. You'll still have plenty of wheel-well clearance. Plus, you'll have a bit more ground clearance as an added benefit. EDIT: BTW, I'd buy them here @ only $59 ea. INCLUDING shipping to your door, and you could also take advantage of the $50 rebate that's currently being offered to bring the price down even more! http://www.discounttiredirect.com/di...w=false&cs=185 Last edited by kimona; 10-29-2010 at 04:34 PM. |
^^^ +1
Order them quickly. Apparently stock is low on this tyre in this size.
They don't come in 185/65 14? That's the tire size I run in the winter.
#18 | |
http://www.tirerack.com/tires/tires....MAXA&tab=Sizes |
| Sedan Grill Options | tuckevalastin | Cosmetic Modifications (Exterior/Interior) | 15 | 12-29-2008 11:59 PM |
| What aftermarket exhaust will fit the Yaris Sedan? | dngz | Performance Modifications | 2 | 10-02-2006 02:41 PM |
