Old 11-15-2010, 08:29 PM   #1
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
My radio dont work, HELP!!!! FIXED
I was trying to fix my remote wire and now my radio dont work. i didnt pull the neg terminal off. i checked all fuses and all good( atleast the fuses i could find that had to do with the radio. i think i just blew up my radio! please say it isnt so! thanks
"who the cap fit let them wear it"
20104dr is offline   Reply With Quote
Old 11-15-2010, 08:43 PM   #2
Check the DOME and ACC fuses in the under dash fuse panel (The one that is literally under the bottom of the driver's side of the dash).
Old 11-16-2010, 12:01 AM   #3
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
tried it they all good
Old 11-16-2010, 01:31 AM   #4
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
You have a DMM or a Light tester to check if the wire harness is getting power ? Do you have an aftermarket radio ? If so it should also have a fuse right by the harness, you can either check it visually or continuity test it with the beeper function on a DMM (Digital Multi Meter ) You'd wanna check the Yellow and Red wires on the harness going to the radio for 12 volts using a meter or for the light to turn on with a light tester, only thing about a light tester is it'll tell you if voltage is present but not how much. If you have power there then check the ground wire.
If you don't have power then there's a fuse out. I'd troubleshoot it before making any HUGE assumptions like i blew my radio.
Good Luck
Old 11-16-2010, 02:36 AM   #5
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
thanks will do but i checked all my fuses n they are all good
Old 11-16-2010, 02:41 AM   #6
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
oh and no aftermarket radio, stock!
Old 11-16-2010, 06:43 AM   #7
How did you check the fuses? If just by looking at them, the smaller value ones can pop without looking like they are popped. I prefer to check them with an ohm meter for continuity or to simply swap in a new one.
Also, is there anything besides the radio that is not working (interior lights, specific dash lights, etc.)?
Old 11-16-2010, 08:55 AM   #8
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
That's the thing everything does work! Just not the radio!
Old 11-16-2010, 08:57 AM   #9
OK. In your initial post you mention that it happened when you were fixing your remote wire. Is that the remote wire for an amplifier? Also, did you check to make sure that one of the radio's connectors is not just loose?
Old 11-16-2010, 09:10 AM   #10
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
I am gonna have to tear it apart later today! Go to go to work thanks for info and comments I will u posted!but you know the wire I used to wire my amp was the wrong wire I think, cuz I had to wire in a switch to turn my amp off! It is a light blue wire.
Old 11-16-2010, 09:56 AM   #11
You actually want to use the grey wire on that same connector, which is accessory switched power. The light blue is constant power for maintaining the radio's settings.
Old 11-16-2010, 09:34 PM   #12
20104dr
CLIFF
20104dr's Avatar
Drives: 2010 4dr
thanks CTScott and s7v7n for the help! i re-checked all my fuses(all were good), ohmd out harness found evrything working. so i plugged evrything back and BAM! it worked. cant explain what hapened or how it works now but it does, weird! i think it was the good vibes i was feeling from you two helping me out, thanks again!!!
Old 11-16-2010, 11:18 PM   #13
_S7V7N_
_S7V7N_'s Avatar
Glad it worked out for you
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
CB radio and new CD player installed! Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 13 06-10-2009 08:27 PM
Standard FM radio does'nt work RickB In Car Entertainment + Electronics (audio / video / alarm) 4 04-04-2009 06:03 AM
I want to trade my Upgraded built in radio... matthewallanstill Items for Sale by private party 0 09-03-2007 09:50 AM
