Old 11-26-2010, 08:10 PM   #1
maik
maik's Avatar
Drives: Black & Red yaris 2007
Question Plz i need an answer?
Hi everybody
i have 2007 yaris HB 5 Doors
my Q is when i drive my car i feel every thing on the road like:
small stones or the road with rough surfaces.
i need to know is it because the car is not heavy or the Tire size is small.
maik is offline   Reply With Quote
Old 11-26-2010, 09:07 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
need to lower your car.
Old 11-26-2010, 09:24 PM   #3
Kal-El
Kal-El's Avatar
I assume everything is stock?
Stock form is designed to be as smooth and quite as possible with the exception of replacing the stock tires with a set specifically designed for noise reduction. Other mods like larger wheels/lower profile tires and lowered suspension will make these complaints much worse.
Also, what type of car are you used too? If you're coming from a Camry, for example, then you can't expect the same level of refinement over the road. The Yaris is very smooth compared to many competitors. Go test drive a Honda Fit and you'll think the Yaris is as smooth and quite as a Lexus.
Old 12-04-2010, 02:54 PM   #4
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
details=better diag of your problem
provide details:
did you buy it used: 1st owner,2nd,3rd,....?
how many miles/km?
stock or modified?
if moded whats on it
OTA'sTOY is offline   Reply With Quote
Old 12-04-2010, 03:49 PM   #5
maik
maik's Avatar
Hi OTA'sTOY
i am the 1st owner
i bought the car from Dubai Toyota Agency so it is a stock
and the motor = 1.3
Old 12-04-2010, 05:11 PM   #6
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
could be tires are over inflated.. double check ur tire pressure..
Old 12-04-2010, 06:00 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by maik View Post
Hi everybody
Crappy OEM tires. Time to upgrade.
Plz help re: LED lights sleey0 DIY / Maintenance / Service 4 07-23-2010 09:55 PM
plz can any body help me zoro2002 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 11-16-2009 04:42 PM
YarisBueller (admin) please answer your PM and emails TWM Performance Suggestions - Feedback - Questions 17 10-05-2009 12:35 PM
