Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 12-26-2010, 05:45 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
TS 1800cc wheel change
hey guys , got a question and need some advice
as you all know , the TS came out with 17inch wheels , i was thinking of possibly changing to 15inch , with a 205, 55 , 15 tire. i know it will slightly effect the speedo reading but my main concern it torque steer and understeer on the corners because the car currently has apporx 180nm of torque. as oem spec is 205 , 45 ,17 inch , i dont wanna mess to much with oem sizing , i just thought the car may go better with the smaller wheel setup , what is your toughts?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 12-27-2010, 12:32 PM   #2
revolution
Drives: 2009 JDM Toyota Vitz
Hi,
I am running 205/55/15 Kumho Ecstas and they are fantastic... I have the JDM RS, which is very similar to the TS,. Had no problems at all with this setup and I did do the calculations based on Wheel Diameter to check if the difference would have an effect. With the size that i put i managed to reduce the margin to less than 1%.
By the way, if you have the stock TS 17s and you do wanna sell, do let me know as I'm looking for a set of those... Im wanting to go back to 17s purely for aesthetics...
Cheers!
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 12-30-2010, 02:52 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey buddy
thanks for the input , thing is my car makes 180nm torque , so 15inch might cause a bit more torque steer than the 17's , so i recon i might stick with the 17's , i dont have the TS wheels on as i sold them to get my super lightweight ones.
JDMtuner
www.jdmtuner.co.za
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
