![]() Drives: Soon Join Date: Nov 2010
Forgive me for i have sinned.
I accidentally hit and maintained 7k rpms for like 2 seconds. I wont get into the reason why hahahaha >.>.
Its a new car too and i felt so bad for fucking up so badly. How much damage did i do in reality? (i dont usually go above 3k/4k rpms daily - no point in lying about it)
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
For two seconds? One time only? On a warmed up engine? The answer should be none. Unless your car is behaving in some way that makes you suspect that something is wrong, I wouldn't worry about it.
How did you manage to do that when fuel cut-off is at around 6450 rpm?
#4 | |
Part that bothers me though is everyone is telling me that shift limiter kicks in at 6.2 but i was clearly in the 7.1-7.2 range. What gives, am i a real life initial D?
![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Modern engines are designed to endure that, also you will never be able to reach redline. It stops at about 5800 RPM if your redline is 6000...
In motion or neutral?
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Iin motion. i have a base model, maybe i didnt get a rev limiter?
![]() Drives: 2007 Hatchback Join Date: Dec 2010
Just out of curiosity......What makes you feel that you damaged the engine? Is it making some funny noises or something? Is it not running right now?
was at a red light in 1st, happened as i was attempting to shift to 2nd.
![]() ![]() ![]() Drives: 2010 Yaris Bayou Blue 3DR Lift Join Date: Sep 2010
Were you wearing platform boots when you did this? Just curious.
#13 | |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
I've done this a couple times with mine too in 1st and 2nd with no problems. Just don't plan on turning this into a habit.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#14 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Making a decision without following it with an action is still a fantasy. |
![]() ![]() ![]() Drives: 07 liftback Join Date: Nov 2008
this has hopefully gotta be a joke thread.... cuz this might be one of the most retarded whines I've ever seen, lmao....
"OH NOES!!!! I HIT THE REV LIMITER AND IT BOUNCED OFF IT A FEW TIMES!!!!! MY CAR IS RUINED!!!" i've bounced off the rev limiter countless times, as have MANY others on this forum, in 1st, 2nd, 3rd, and i've tried my damn hardest to get it to do the same in 4th, but the gov kicks in too soon. Unless you sit there and just sit in your driveway and hold the gas on the floorboard for like 3 straight minutes, odds are, you won't damage anything. Hell, it's suggested to go through a full range of rpms during a break in period to just ensure everything settles in correctly.
+1, this happened to me the other day too, my rev limiter before has stopped me around 6.7k but for some reason i got past 7.2 the other day and it was still on the rise.....
If it has boobs or wheels sooner or later your gonna have problems with it ![]() |
#17 | |
Joey
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Yeah know need to go negative on the OP. This is a legitimate question and concern.
A break in period is still a good process to take although it isn't nearly as important as on past cars. Today's cars can take far more abuse and are already built to much tighter tolerances that require little "settling" of engine components. Still, automakers recommend these break in periods that suggests limiting RPM, very high speed, jack rabbit starts, and long sustained speeds. The OP has every right to wonder if he may have affected long term durability. That said, I don't think there's anything to worry about from this example especially on a proven to be bullet proof engine. Today's cars are extremely resilient to abuse. Check out these torture tests for Ford's new EcoBoost engine in the F-150. And this is with no break in. http://www.ford.com/trucks/f150/expe...9m2nop20101101 |
Thread Tools | |
Display Modes | |
