AKA Samurai Racer
Engine upgrades
HI Guys
Im planning some engine upgrades soon , eg , camms , gas flow , throttle bodies and a de Cat exhaust , and a ECU upgrade , maby bigger injectors..any advice on the yaris 1.3 engine mods? i think i should get around 100 KW. |
Who said Yaris was slow?
Sorry dude, but you won't find much info about the 1.3L engine on this forum. 99% of the guys drive the 1.5L USDM USDM engine.
![]() ![]() ![]() Drives: um not a yaris but hopefully Join Date: Dec 2006
And for the 1.5 here in the us atleast there is I think header,cai,exhuast and that is about it. But I dont really look around on the net so I cant tell u for sure.
AKA Samurai Racer
im going to one of the local top tuners next week , and get a custom throttle body made up , see if i can get my ECU remapped , and also find out about degreeing my cams and flowing the head.Will let you guys know what they say.And i also wanna put my car on the Dyno to see what see's doing.
What the...?
Drives: '06 Blazing Blue 3 door RS. Join Date: Oct 2006
Um, your TB is a Drive by wire that is servo controlled, meaning that your TPS sensor is under your gas pedal and the ECU is actuating the TB. unless all you are doing is putting a bigger one on from another toyota, you should re-think this...
AKA Samurai Racer
what u mean? are you talking about the pressure sensor?
I took my yaris to a dealership to have the ECU and engine checked out , all seemed ok , although all they check for is errors, and if none , then to them , everything is ok , the only thing they could do was turn my warning buzzer off for the seatbelt. one thing they showed me is that as a factory default , the throttle or gas pedal , is set to a maximum of 81.1 % , wierd hey?almost detuned. |
so WOT isn't WOT?
interesting....... In this case a larger throttle may be useful... Or an ECU tweak, somehow?
| Engine Swap | Nutzoids | Performance Modifications | 42 | 10-01-2007 06:20 PM |
| if i am thinking about an engine swap - from 1.3 to 1.5 - please help | ASHRAF | Performance Modifications | 15 | 01-03-2007 01:40 PM |
| Engine mods - why bother? | RallyYaris | Performance Modifications | 143 | 12-24-2006 03:56 AM |
| Engine Working too hard? | David81 | General Yaris / Vitz Discussion | 8 | 06-14-2006 11:17 AM |
| Noisy Engine | David81 | New YARIS Purchase Forum | 8 | 06-02-2006 12:15 PM |
