A/F Ratio (AFR)
Hey guys. Does anyone know if the AFR gauge on the SGII will work on the Yaris? I'm not sure if I'm plugging in the right one. I used the alternate AFR (general) under the ISO section: http://www.scangauge.com/support/pdfs/XGAUGE.pdf
Am I using the wrong codes? Nothing was displayed when I inputted the codes. Thanks in advanced. |
#2 | |
Dang, so it's not possible then with a SGII. Wishful thinking. lol. Thanks guys.
What is a "PID" anyway?
PID means "Parameter ID". The OEM proprietary ones require communication with different CAN bus IDs, which is the part that most aftermarket code readers don't have the ability to do.
| Q about placement of wideband A/F sensor | LtNoogie | Performance Modifications | 15 | 05-09-2012 12:03 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| VIDEO: My A/F readings according to my wideband | PETERPOOP | Forced Induction Forum | 6 | 04-19-2009 01:39 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
