Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
I looking at several ENKEI wheels and found "tirerack website" two sizes for the 2007 yaris HB.
15 x 6.5 195/50/15 (car) 16 x 7 205/40/16 (car) I've decided that I like the 15" or 16" v/s 17" or 18" primarily because I'm using my Yaris as a daily driver. I'm not completly sure about the 6.5 or 7 any comments? Would the 6.5 be better than the 7? Thanks Ron |
der Zeck
195/50r15 = wrong for Yaris, if you are going 15x6.5 I would go 205/55r15, relitivly low priced tire, and will run flush with a 6.5 inch wide wheel, as well as staying very close to the stock diameter tire... this same size tire would run fine on a 15x7 wheel as well
and if you want to run a 16 inch wheel I would go 215/45r16to get the closest overall diameter and fit nicely on a 7 inch wide wheel
id go with the 16x7, 205 or 215/45/16
![]() ![]() ![]() Drives: um not a yaris but hopefully Join Date: Dec 2006
y
Y would the 205/50/15 b a bad choice? I have a eagle talon and was going to run eather the 205 or a 225/50/15.
der Zeck
225-50-15 would be a good choice, it is very close to stock diameter, 205's would be way too small, throw the speedo off too much, and it just would not look right
both of those sized are pretty small for a Talon as well 215-60-15 would be more like what you need
![]() ![]() ![]() Drives: 2007 Yaris Liftback, 5-speed Join Date: Oct 2006
Would 195-55-15 be OK (they're close to the stock/optional 185-60-15's in diameter and will fit on the 15 X 5.5 alloys)?
Well I like width and low sidewall. If I have a problem with wheel gap I will just lower it. I am more into how it will handle than how it looks. If I buy a yaris the looks will probley be one of the last things I will do.
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
There are plenty of 15x7. That is what I recommend on this car.
Personally I run 225's and they fit to my liking. On a car that you drive daily I would stick with 205's or even 215's |
der Zeck
suggested tire sizes to stay as close to stock as possible
185-60-15 stock 205-55-15 +1 225-50-15 +2
| Feedback on these wheels | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-04-2007 08:09 PM |
| Rim size difference???? | marcus | General Yaris / Vitz Discussion | 2 | 11-03-2006 03:20 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
| Size of steel 15" wheels? | ketel0ne | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-08-2006 11:37 PM |
