Old 03-11-2011, 06:56 AM   #1
Johncypus
Drives: Toyota Yaris GLD D4D
Bonnet replacement
Whilst driving my wife's pride and joy (a 2003 silver D4D diesel ) a pheasant flew into the bonnet leaving a bump the size of a football. I've sourced a second hand bonnet from a breaker. This bonnet is from a petrol model, does any one have any tips re the fitting of the replacement, I'm hoping the transfer of the under bonnet padding is going to be straightforward matter!
Thanks in anticipation,
Johncypus is offline   Reply With Quote
Old 03-11-2011, 11:03 AM   #2
It should be a direct replacement, BUT just lose fit it before the bolts are firmly tightened and lower it checking the fender and bumper clearance is the same all around. Not too sure about the padding. Depending on were it was assembled and what line, the holes might be punched or they won't. If not, an easy drilling is in order and you're good to go. Generally on cars in multiple markets, the holes will be "soft punched" to show where you should drill. Best way to tackle that one would be before you put the bonnet on, place the padding on and mark your holes, center punch them and then drill to required size.
Good luck. If you have time, take some pictures of your process and throw them in the DIY section in case someone else needs a reference.
Old 03-11-2011, 12:14 PM   #3
^ good advice. The hinge holes have some adjustment in them, so you can make adjustments in the gap to the rear, front and sides.
Best replacement tire size for stock rims? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2010 05:27 PM
Yaris CF bonnet and hood damper 007 Yaris Australia 4 10-01-2010 12:28 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 11:25 AM
Front seat replacement Henry G. Cosmetic Modifications (Exterior/Interior) 5 07-23-2010 12:54 AM
Carbon Bonnet 33lam Australia 8 11-18-2008 09:29 PM
