Old 03-16-2011, 03:36 PM   #1
Yaris4L1fe
Drives: 2010 Yaris Sedan
Help Guys!! Wheel & TPMS Question!
Hi Everyone!
i just bought my 1st Yaris this past weekend. Its a 2010 Yaris sedan. Think stock tires are 15". Im considering purchasing these 17" rims for it off ebay (see below link) Let me know what you guys think and if ill need to do anything extra other than throwing them on when i get them? Also i dont plan to purchase any TPMS sensors for these rims so what kind of probs will i come accross? plan to use the rims in the summer but throw back the stock wheels and tires in the winter so will the TPMS recognize the old tires when i throw the stock wheels back on? Thanks in advance everyone!!
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Yaris4L1fe is offline   Reply With Quote
Old 03-16-2011, 03:53 PM   #2
edmcc
What the Pho?
edmcc's Avatar
Drives: '08 Meteorite Metallic MT LB
Originally Posted by Yaris4L1fe View Post
Hi Everyone!
Oh yea they will. your warning light will be on all spring and summer but will go off once you put your steelies back on.
edmcc is offline   Reply With Quote
Old 03-16-2011, 08:33 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
You could install the TPMS from your steel wheels.
BTW, spend the additional $40 and get the 205/45/17's.
Old 03-17-2011, 12:03 PM   #4
Yaris4L1fe
thanks for the info guys!! makes sense to go w/ the 45 series as roads are pretty bad here in MN... =)
Thanks again!
Old 03-17-2011, 07:27 PM   #5
kimona
kimona's Avatar
Thanks again!
Yes, JDM OEM size is 205/45/17, so you'll have good fitment.
Old 03-25-2011, 10:01 PM   #6
Hershey
TPMS question about reprogramming
I just bought used 15 " rims with the TPMS. They are from a 2008 Yaris. Do you know if they would be compatible with a 2010 Yaris or would they need to be reprogrammed. The toyota dealer we went to thought they would need to reprogrammed. I didn't think they would.
Thanks
Old 03-25-2011, 10:25 PM   #7
Thanks
The Yaris TPWS ECU can only store four sensor IDs, so to switch back and forth you would need to have them reprogrammed by a tire shop or the dealer. And, the 08 sensors are the same as for the 10.
Old 03-25-2011, 10:36 PM   #8
Hershey
Thanks CTScott
Old 03-25-2011, 10:29 PM   #9
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I've just gotten used to the TPMS light being on. One day I'll stop being lazy and disable it. It was going to cost $500 for me to get that installed on my new wheels. I can just do a walk around every time before I get in the car to save $500.
Old 03-26-2011, 06:04 PM   #10
Hershey
CTScott , these rims pictured are from a 2008 . Would we need to have them reprogrammed if we used them for our 2008 sedan ? Also would we be charged for the reprogamming ? Sorry , we're a bit confused . Thanks again . Here's the pics of the 4 rims w/ T.P.M.S. for $85 each . Come with a 1 year warranty , including the T.P.M.S.. They were also checked for balance . Seem to be in good condition for being 3 years old .
Old 03-26-2011, 06:21 PM   #11
SAV912
Pirate Yaaaaris
SAV912's Avatar
Yes. The IDs in your car are going to be paired to the tires on your car currently. Swapping within model year doesn't make a difference because the car only stores the four IDs with the four tires already on the car. Take those tires off, and put the new rims on, and you will have to have them reprogrammed. Or disable the light/TPMS system. Your choice.
Upwards of $300 for some stock steel wheels seems a bit steep though. But that's a different matter.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 03-26-2011, 06:30 PM   #12
Hershey
We've been trying to get rims for a few years . They're rather scarce in our region . Probably due to the winter and fewer YARIS on the road that end up in a salvage yard . Don't forget these have T.P.M.S. too . Would cost a bundle through the dealer .
Old 03-26-2011, 06:39 PM   #13
SAV912
Pirate Yaaaaris
SAV912's Avatar
The TPMS is a plus, but it's sorta outweighed by the fact that you'd have to have them reprogrammed anyway. Install is going to be more expensive than reprogramming, but I don't know by how much.
-C
Georgia Bulldogs!
Old 03-26-2011, 06:59 PM   #14
Hershey
Install ? The tpms is already on the rims , if that's what you're referring to . It'll save us $60+ a pop at twice a year for having the snows and all season tires mounted and balanced in the coming years . Better for the tires and rims as well .
Old 03-26-2011, 08:45 PM   #15
SAV912
Pirate Yaaaaris
SAV912's Avatar
I meant install on different wheels instead of steelies. But if you're willing to shell out to reprogram twice a year, by all means, go nuts. Are these going to be the winter wheels? If so, then I agree and I'd just get steelies. If these are the summer wheels, I'd look into something other than steelies. Even some Scion xA or 1st gen xB wheels.
-C
Georgia Bulldogs!
Old 03-26-2011, 09:19 PM   #16
Hershey
Already bought them . Most likely stick them on the '08 sedan with the GOODYEAR Eagle LS all season tires that are in storage . There's snows on it for now .
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
Question for the audio guys.. vacantj In Car Entertainment + Electronics (audio / video / alarm) 3 09-23-2007 11:40 PM
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 11:13 AM
