![]() Drives: 2009 Yaris Join Date: Jan 2010
Warrany Service Problem?
I recently discovered a scrapping sound on my Yaris when the steering wheel is turned hard right. The dealer that I have servicing the car informed me that the rotor is rubbing against the backing plate. He also quoted a price to fix the problem. Confused, I told him that the car still has less than 36K miles on the odometer; therefore, the repair should be covered under warranty. He then tried to say that the guy who replaced my pads caused the problem, which was news to me because the car still has the original pads. He retorted that the pads could not be the original pads because they looked new. I know for a fact that the pads are original, that is, unless they were replaced by the brake fairy in the middle of the night. The reason why they look new is because I am a very conservative driver (i.e., I drive like an old man), and 95% of the mileage on that car is highway mileage. Has anyone had this type of problem with their Yaris?
I guess that I should have caught this problem sooner. However, I rarely make turns that require turning the wheel hard right or left, and the sound is easily missed with the windows rolled up and the radio on. If push comes to shove, I will pay for the repair, but I will send a nasty-gram about my experience with the dealer's service department to Toyota Motor Sales, USA. |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
What did he quote for the repair? I ask because it usually involves tightening or tweaking the backing plate. It should be a fairly simple repair.
If it really is just the rotor scraping against the plate, then it may simply be that the plate is bent (from road debris, etc.) If that is the case, the fix is simply to flex the plate back to where it should be, as the plate is just a thin piece of sheet metal.
TRIM HUNTER
IF Toyota tech had REALLY addressed your concern he would have seen under inspection that your pads were indeed toyota ones. i believe this dealer is trying to imply that your noise is from something you hit rather than a warranty issue.......
![]() ![]() ![]() Drives: 08 2Dr LB Base, Silver Join Date: Jan 2011
You should take it to another dealership and never go back to the first one for anything again. Sure, it may be a simple fix, but for them to imply that your brakes are new and therefore not their problem is sub-par.
BTW, in addition, reading between the lines, they called you a liar to your face. |
| I hate cable service providers. | Altitude | Off-topic / Other Cars / Everything else Discussions | 27 | 09-12-2010 09:09 AM |
| Service at Toyota local dealer | beZzZ | DIY / Maintenance / Service | 22 | 05-07-2010 07:23 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
| Funny Business at the Toyota Service Centre | *MAD DOG* | DIY / Maintenance / Service | 10 | 01-10-2009 12:47 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
