Old 07-12-2007, 02:58 PM   #1
thatboyjer
thatboyjer's Avatar
Drives: 5spd 2007 Yaris LB
lug nut spacing
My bad if this has already been answered before. Anyways i'm getting my Yaris LB soon and my brother wanted to get me some rims before he leaves outta state. He told me to ask around if the car is 4 x 100 or 4 x 114.3 or something like that. I'm not sure but hopefully ya'll can help me out a bit?
thatboyjer is offline   Reply With Quote
Old 07-12-2007, 03:15 PM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
They are 4x100...
Old 07-12-2007, 06:48 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by slvryaris View Post
They are 4x100...
Old 07-12-2007, 07:05 PM   #4
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
4X100
SPONSORED BY
Old 07-12-2007, 11:45 PM   #5
400?
2x200?
Old 07-13-2007, 01:52 AM   #6
4 wheels x 100 centimeters across
Old 07-13-2007, 02:00 AM   #7
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
how bout the hubs for wheel spacers? i looking for 15mm spacers.........just wondering since we're on the top of the spacing and w/e sorry if it's a bit off topic
Old 07-13-2007, 08:06 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
The Yaris center bore is 54.1.
If you really want to use spacers, don't go cheap!
You can buy Ichiba aluminum/magnesium alloy hubcentric spacers on ebay for about $60 a pair (plus shipping) including longer studs.
Old 07-13-2007, 12:27 PM   #9
kimona
kimona's Avatar
Previous post this thread.
Yup, I think 5mm in the rear with your 40mm wheels should look good!
Old 07-13-2007, 12:28 PM   #10
brickhardmeat
Lonesome Cowboy
coolness I'll check them for 5mm stock
SPONSORED BY
Old 07-13-2007, 11:34 AM   #11
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I found some for $99 from that company but other than that not much for now. What I'm getting is 15mm wheel spacers not just 5mm because the rims i'm using are at a +37 offset i believe
Old 07-13-2007, 11:41 AM   #12
kimona
kimona's Avatar
With a 15mm spacer and a +37mm rim, you'd be running at +22mm.
Well... that's insane on a Yaris unless you've modified and extended the fenders and lowered the car for racing.
Old 07-13-2007, 11:45 AM   #13
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I have no clue haha. When i had the wheels on it wasn't flush with the fender at all....the fender looked like it ate the wheel LOL. all i recall is that it has a 37 offset because i have them in my friends house for now...trying to get new tires for it first.
Old 07-13-2007, 11:46 AM   #14
I just got 10mm spacers for the rears, made by H & R, and sold at www.allsprings.com. They have several sizes for the Yaris, and they are very good quality, and they ship quickly.
NOTE: when you buy, you are getting one PAIR (2), not four.
Old 07-13-2007, 11:51 AM   #15
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
yea. I don't need a pair for the front of my car because the front wheels line up almost perfectly with the fender no spacers needed hehe. for the rear i probably need 10mm or 15mm spacers. wow those H&R brand ones look expensive.
Old 07-13-2007, 12:00 PM   #16
kimona
kimona's Avatar
FRONT: 37mm offset with 205 rubber would stick out a tad.
REAR: 37mm offset with 205 rubber shouldn't be too bad at all. Japanese Vitz owners generally don't run much less than 35mm in the rear for a flush fit.
SO... get the tires, install the package on your car, then measure with a level and mm ruler and see what you'll need.
If your wheels are indeed 37mm's, then you won't need a thing up front and very very little in the rear... maybe 5mm's.
BTW, approx. 42mm up front and 35mm rear is a typical Japanese application using staggered offsets
Old 07-13-2007, 12:02 PM   #17
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
alright. thanks for the help man.
Old 07-13-2007, 12:15 PM   #18
brickhardmeat
Lonesome Cowboy
I have +40 offset and I would like to push the rears out a tad. I think 5mm would do it for me. That would put me +35 in the rear. Now, I want some advice.....don't you think the stock bolts will be fine with just a 5mm spacer? Should have plenty of thread to tighten my nut huh?
this is what I am planning to grab
http://www.racinglab.com/whmalialwhsp1.html
SPONSORED BY
Torquing those Lug Nuts... Doc Zaius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-13-2007 12:19 PM
Cheap Lug Nuts? KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-06-2007 12:51 AM
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
5 lug adapter? funkstrong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-21-2006 04:49 PM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 05:58 PM
