Tranny Fluid
Just curious for any of you with manual trannys, what kind of tranny fluid you are using? I'm at 90,000KM and overdue for my first transmission fluid change. Been reading that Red Line and Amsoil are both good choices if wanting to switch over to synthetic. I guess the Yaris only requires 2 Litres so it wouldn't be expensive at all.
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I use royal purple.
redline mt-90 in mine...
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
![]() ![]() ![]() Drives: 2004 Echo HB Join Date: Oct 2008
MT 90. I hate to say it but Canadian Tire can get it. May take a day or two.
i got mine at JRP in mississauga
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
Performance Improvements has it too I think
05' Echo Hatch - Greddy Supercharger - rear disc |
Sweet.. I'll check Crappy Tire because JRP and Performance Improvements are both a good 1hr+ commute each way.
Thanks!! |
hey, are the Royal Purple good?
i have castrol syntec in mine since 68k km. My gears has been grinding since...i'm at 103kkm |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Redline MT-90, what a difference in made in shift quality.
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
This, because it's GL-4 spec'd, which is what my Echo's tranny needs.
GL-5 will not be friendly to your tranny if you need GL-4, check your manual.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
since you should have changed it 33000km ago?
#14 |
uhh... shouldn't it be changed at every 65k?? I only did 35k so far...?
Hmmm.... Should i try Royal Purple or go back to OEM?? |
#15 |
tranny fluid change is every 60,000km, not miles...
#16 |
so should i even try royalpurple??
#17 |
![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
I used Amsoil, got it at Autopro. Only changed it once at 200,000 kms was really pleased with it, made a noticeable difference. (that was in the echo)
#18 | |
The fluids that are GL-4/GL-5 compatible don't do as good a job as ones that are strictly GL-4 compatible.
| what!!!! 4 quarts of tranny fluid? | Moses | DIY / Maintenance / Service | 11 | 03-25-2010 01:25 AM |
| Used TOYOTA WS Automatic Tranny Fluid analysis : | Hershey | General Yaris / Vitz Discussion | 15 | 03-18-2010 07:29 PM |
| Does Yaris and 2000 Corolla use same type of tranny fluid? | Yawesh | DIY / Maintenance / Service | 6 | 06-23-2009 04:55 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 11:57 PM |
| soo whos gonna change their tranny fluid | twixt | DIY / Maintenance / Service | 0 | 08-04-2006 04:09 AM |
