Old 04-16-2011, 02:43 AM   #1
tahir44
Drives: Vitz
Send a message via Yahoo to tahir44
How to Reach Trouble Codes without Scanner?
Can anyone help in reading engine trouble codes without scanner, as earlier I had suzuki esteem with building in OBD, code reading was easy by jumping DIAG Fuse without any scanner.
SO is there any solution for Yaris 2006 to read OBD codes without scanner
tahir44 is offline   Reply With Quote
Old 04-16-2011, 03:03 AM   #2
aareyn
aareyn's Avatar
Drives: yaris sedan
Go to the auto parts store and use theirs?
aareyn is offline   Reply With Quote
Old 04-16-2011, 03:30 PM   #3
I think you have to plug in a device to the OBDII to read codes.
Old 04-16-2011, 04:21 PM   #4
Yeah, as far as I know there are no tricks to obtain the codes without a scanner. That's one thing I like about my Dodge. Chrylser/Dodge vehicles will show codes in the digital odometer if you turn the ignition key to the accessory position 3 times in rapid succession. Won't clear codes, but at least you can read them.
Old 04-19-2011, 08:45 AM   #5
tahir44
Drives: Vitz
Is there any free scanner software for computer and interface cable to connect that with CAR ECU ?
Old 04-19-2011, 09:55 AM   #6
check eBay... but I think for the price of a good adapter you might as well order a ScanGauge, it has a lot of other useful functions too.
Trouble Code P2121 1nz DIY / Maintenance / Service 9 09-02-2024 07:59 AM
Scanner tool bieniman In Car Entertainment + Electronics (audio / video / alarm) 3 12-21-2010 02:59 PM
P2420 and P0441 codes jkonrath DIY / Maintenance / Service 3 09-05-2010 09:33 PM
Alternator Trouble butter DIY / Maintenance / Service 1 08-10-2010 03:39 PM
Actron CP9135 Scanner regal DIY / Maintenance / Service 6 11-08-2009 11:29 PM
