Old 11-16-2008, 12:58 AM   #1
eric81
eric81's Avatar
Drives: Toyota Salesman
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners
I highly advise that anyone who owns a Yaris and wants to replace the exhaust header, please read this. Anyone who has already replaced their exhaust header can verify. The factory A/F mixture sensor that is "screwed" into the manifold by the factory is cross threaded, and therefore won't come out. I actually broke mine in half trying to get it out. So, I bought an aftermarket eBay brand A/F sensor on eBay (duh) for a "great" price, and it turns out it almost cost me a new engine. I thought the power was starting to slide a little bit, especially for having a CAI, Megan header, and 3A racing muffler (not really a muffler, as it doesn't muffle or restrict air in any way at all). After I replaced the header, the check engine light wouldn't turn off, and I was running rich all the time, so I forked over the cash to NST (great prices and products... highly recommended) and they shipped me a replacement A/F sensor, and the light went out right away. What I hadn't realized was the damage caused to my engine in that 500 miles I drove with the car running so rich. I just pulled the plugs to check them, and they were burnt to a crisp. I bought replacement ones for about $30 for the set of 4 (yes, I stuck with Iridium's) and set the gap to 44, and started the car. Black and grey smoke came flying out. I also bought some piston, ring, and valve cleaner that I will be using the next time I fill up. My neighbor swears by it, so we will see. Anyways, from my understanding, one or two more thousand miles and I would have just cooked the engine right off. Please plan to buy a new A/F sensor when you buy a new header. And check the plugs soon after the replacement, just to make sure. Drive on!
eric81 is offline   Reply With Quote
Old 11-16-2008, 01:04 AM   #2
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
i can personally confirm this! you are the third person other than myself who has experienced the cross threaded AF sensor.
Wanted: Forced Induction
Old 11-16-2008, 01:34 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
LIVE AND LEARN I GUESS
I would hope going beyond changing oil in a car, people would take the time to research the "mods they are doing" there is a reason after all they are called modifications.....
it will save you time and money in the long run if you do some research on what exactly you are repairing when a part breaks and what that broken part affects
but I don't know your situation and if it's like me you probably have your car as a daily driver and couldn't afford for it to be down for too long....which is why you did what you did I dunno....
I'm not criticizing you at all nor am I attempting to sound combative towards you, please don't take offense.
Old 11-16-2008, 12:34 PM   #4
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Are you guys talking about the oxygen sensor?
Reddog99 is offline   Reply With Quote
Old 11-16-2008, 12:57 PM   #5
BailOut
Steals terrorist's lunch
BailOut's Avatar
Excuse me while I go hug my perfectly working stock ehxaust system.
- Brian
Share the Road
Old 11-16-2008, 07:01 PM   #6
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
So the exhaust has an oxygen sensor AND an "A/F mixture sensor"?
Here I am thinking that the oxygen sensor IS an A/F mixture sensor.
Old 11-17-2008, 09:50 AM   #7
1stToyota
1stToyota's Avatar
Toyota calls their upstream O2 sensor an A/F mixture sensor.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-16-2008, 07:40 PM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
The sensor is an O2 (oxygen) sensor and is matched to fuel signals sent by the ECU to the injectors.
Sounds like a clumsy pair of hands that reinstalled the O2 sensor. A bit of grease on the threads always makes things easier. And you ignored the dashboard warnings - a car wouldn't start throwing codes for no reason. Mine didn't so much as flicker when it started up, and I never saw a CEL after months of driving around with my header and exhaust install.
Its another reason to track your car's fuel consumption and other vital fluids. When it starts consuming too much fuel, engine oil, or coolant, you should start looking for the problem, or letting a mechanic have a look at it.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-17-2008, 12:12 AM   #9
eric81
eric81's Avatar
I saw the codes, and started asking lots of questions to everyone on Yaris World. (I was ergatzke before.) I knew the sensor was wrong, just didn't understand what it was doing to the engine. The car ran rich for a long time, and was very fast and loud. Thought it was just a really nice header. Now I know it was because the A/F sensor (which reads how much fuel is being burned compared to how much is not) was not right. The O2 sensor reads how clean or consentrated the oxygen and carbon mixtures are coming from the engine. That part is for economical reasons, like saving trees and what not. (that is right, isn't it?) I also thought part of the CEL (check engine light) problem was that I was letting way more air into the engine with a CAI (cold air intake) and letting far more out with an exhaust header and racing muffler. I am letting the engine breathe far better, but it is not near enough to throw a CEL. The problem is fixed, and I am once again running nice and smooth. I changed plugs and it is running better, and used Lucas Engine Cleaner to clean the rings, pistons, and valves. It seems to have worked because my drive to and from Portland from Olympia was easy, and I was KILLING IT on the highway. Hit 100 once with ease. (Yes, that is 100 MPH, not 100 KPH) I am not a certified mechanic, but I did stay in a Holiday In Express once, and I can tell you this engine is fairly simple, and anyone can figure out that if they did something to the engine, and the CEL turns on, it is probably their fault.
And I don't mind people being a little offensive, but thanks for the clarification.
Old 11-17-2008, 01:24 AM   #10
ddongbap
Actually, a car running rich doesn't really do much. The darkness is actually improperly burnt fuel. You'd be in trouble if the spark plugs were white-ish. You really weren't in TOO much trouble by a rich running car.
Old 11-17-2008, 01:59 AM   #11
eric81
eric81's Avatar
From my understanding, many a people have thrown pistons that way. But our cars are pretty low on the power, so you are probably right. Still, it was pretty bad in my engine. And it smoked BAD when I put the new plugs in. It is all nice now. I will check the plugs in about 2 or 3 more tanks. I will also post a pic of one of the bad plugs here tomorrow sometime. It is WAY burnt up. All black and stuff. My neighbor even felt bad for me.
Old 12-03-2008, 03:54 AM   #12
GeneW
Drives: 2008 Yaris
Black plugs aren't a big deal, unless they're oily. When you run so rich that the gas fumes dissolve the oil on the piston walls then it's a bad time. You gotta really really run rich to do that....
Now if you run super lean.... omg is that tough on the exhaust valves! I had a 73 Chevy Nova that had an orange glow under it from the exhaust manifolds glowing orange because of a lean mixture.
Gene
Old 11-17-2008, 11:10 AM   #13
Correct, and it's a very unusual 0-5v sensor, made by Denso for Toyota OEM. No one else makes it, and you have to get it from Toyota (or a salvage yard )
The rear one, between the cats, is an O2, however.
My header install went fine -- no cross-threading and no CEL's.
Old 11-17-2008, 11:29 AM   #14
1stToyota
1stToyota's Avatar
I bought a Bosch replacement not too long ago. No comeback yet...knocks wood
2008 Scion xD
Old 11-21-2008, 12:56 PM   #15
Black Yaris
der Zeck
Black Yaris's Avatar
We sell Denso at AutoZone
Old 11-21-2008, 10:09 PM   #16
Shroomster
Shroomster's Avatar
*cough* you apparently don't sell the door edge protectors at least to me from your store...pre hack
Old 11-17-2008, 11:33 AM   #17
ChinoCharles
Drives: LB
I helped test that Megan header when it first came out and had to install and uninstall it multiple times. Never had a problem.
Old 11-17-2008, 11:57 AM   #18
eric81
eric81's Avatar
Maybe it is just the 08's, or just a certain series of the Yaris, or just a certain month or some other group.
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Need LA Yaris liftback Owners for Yaris Commercial weinsteins General Yaris / Vitz Discussion 10 05-04-2006 04:42 PM
