![]() ![]() Drives: 2009 JDM Toyota Vitz Join Date: Jul 2010
Steering Wheel Audio Controls...?
Hi,
So I found all the part numbers for the Steering Wheel Audio Controls that will allow me to add it to my Vitz RS, but I'm stuck on a little issue... I can order the Silver Trim pieces, Buttons and Spiral, thats easy. And i can get the smaller Steering Wheel Airbag cover as well. But my only concern is what to do about the Airbag? Will i move the Airbag over from the old steering wheel cover? If so, how do i do that? I don't want it going Poof! on me whilst im installing... Any help very much appreciated!!!!
2011 JDM Toyota Vitz RS NCP91-AHMVK Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs... |
#2 | |
To answer your PM questions in a bit more detail, here are some pictures of how the airbag assembly and cover are constructed:
The airbag assembly removed from the steering wheel (note that the popped squib has been removed in this picture): Airbag Cover with Frame.jpg A replacement cover: Airbag Cover.jpg The rivets that need to be removed to separate the airbag frame from the cover: Rivets.jpg The back side of the removed airbag frame: Airbag Frame Back.jpg The front side of the removed airbag frame: Airbag Frame Front.jpg The back side of the removed airbag frame with the popped squib: Popped Airbag Back with Popped Airbag.jpg The front side of the removed airbag frame with the popped squib: Popped Airbag Front with Popped Airbag.jpg The back of the popped squib: Popped Airbag back.jpg The front of the popped squib: Popped Airbag Front.jpg Hopefully those give you a better idea of what you are dealing with. I drilled the rivets on this popped one, but would be hesitant to do so on a live one. The rivets are large, hard, and generate a lot of heat while being drilled. If I were going to swap the cover on a live one, I think I would: 1. Cut the plastic cover around the four rivets. 2. Pry the frame out of the cover (it has a lip that fits into a channel in the plastic, so you have to pry it loose once the rivets are free). 3. Unbolt the squib from the frame (there are four nuts that hold the squib assembly to the airbag frame). 4. With the airbag squib removed, drill the rivets out of the frame. 5. Bolt the airbag squib back to the frame. 6. insert the airbag assembly into the new cover. 7. Rivet or bolt the airbag assembly to the new cover. |
| !!Toyota Belta(Yaris Sedan) Steering Wheel Controls!! | Murtaza_murti | In Car Entertainment + Electronics (audio / video / alarm) | 39 | 01-07-2015 03:33 PM |
| Steering wheel audio contorols - Yaris 2003 | levvy | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 08-31-2013 09:54 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 11:16 AM |
| Steering wheel audio controls? | vodkalush | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 09-14-2006 12:17 AM |
