Old 05-15-2011, 09:30 AM   #1
dzcab
Drives: 2011 3Dr Hatch
17" factory enkei scion xa/xb wheels
I seen these wheels at a local dealership by me on sale for a good price. They are 17x7" wheels with 30 mm offset and Yokohama avid all seasons on them. The tires are 205/40/17. They are brand new wheels and tires. Will these wheels fit on a yaris 3 door? Here is a link to see what the wheels look like?
Also if someone can direct me to a place where I can get some tuner lugs for a decent price?
http://cgi.ebay.com/ebaymotors/17-TO...8#ht_500wt_722
dzcab is offline   Reply With Quote
Old 05-15-2011, 09:50 AM   #2
SKurj
Drives: 09 Yaris 3dr HB, BRZ
The offset is wrong... probably will run into rubbings issues.. think you need to be looking for ET40 or higher for 17x7
SKurj is offline   Reply With Quote
Old 05-15-2011, 10:12 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Yes, offset is too low. Ideally, ET42 or higher would be best with 205mm rubber. Plus, with 17" wheels on stock suspension (or a mild drop), 205/45/17's work best.
Old 05-15-2011, 07:43 PM   #4
dzcab
Would Wheel Spacers help?
Old 05-15-2011, 08:49 PM   #5
kimona
kimona's Avatar
No, wheel spacers would essentially make the offset even lower.
Old 05-15-2011, 11:14 PM   #6
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
They will for sure rub in front if you are on lowering springs,35 offset is about as far as you may want to push it for the fronts.
The rears will most likely rub as well,roll fenders under and you should be ok....that offset is about the same as what I have with 25 offset on 8" wide rim....and I rub on the tires all the time,nothing that cannot be lived with but it can be annoying at times..
Scion in Canada toy_toronto Canada 30 10-04-2010 09:33 PM
Did you lose mileage going to 17" wheels? Mead Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 05-07-2007 11:54 PM
Factory base wheels & tires for Liftback kennywhy Items for Sale by private party 6 01-22-2007 07:31 AM
Enkei RZ5 wheels on Liftback kennywhy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-23-2006 05:22 AM
Factory Lowering Springs + MAX Wheels? What are the options? bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-24-2006 09:10 PM
