![]() ![]() ![]() Drives: 2007 black yaris hb Join Date: Feb 2011
center bore on wheels is too big
ok so i just got my nice new rota wheels and relized that the center bore is a lot bigger . i test fitted the rim and its "loose" or has some play . the hub on the rotas is 67.1. so now im lost and dont know wut to do...do they make rings or hub adapters....need advice.
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
There are spigot rings for that. They're basically plastic rings which make the centre bore smaller and they come in a variety of sizes. If I'm not mistaken, the center bore on the yaris is 54,0 (someone corrent me on this) so you need 67,1 to 54,0 rings for your wheels.
I got some rota's too and bought some rings off E-Bay for like ten bucks
"Because it's Racecar" |
Yes 54.1mm is correct
thanks guys...i found wut i was lookin for right after i posted this...hubcentric rings. now heres the real question do u think my local tire and wheel shop (jackwilliams) will have the rings i need
^ walk in and find out
you can drive w/o hubcentric rings on the wheels.....the lugnuts should be tapered at the end, just make sure you put them on evenly and itll space the wheel correctly on the hub
resident senior
I would get metal rings if I were you , just to eliminate any possibility of melting . Yes I have melted them before . Discount tire direct has the metal rings for $15 ...
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
so.....as long as the lug holes are right they'll suck it up to the hub where it's supposed to be. as long as you dont torque one lug then the next. you gotta tighten them all to touching, then torque them.
I just zip mine on with a cordless drill, then Tq them down with a wrench. No big deal.
i got some hubcentric rings from the local custom shop it was 12 bucks no biggie...if they melt then ill graduate to metal
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
most wheels get balanced mounted in the hub opening; BMW on the other hand has a special tool that goes through the lugstud holes to avoid any centering issues with the hubs when balancing. as long as nuts are on evenly, you are good to go. (good enough for BMW, good enough for me! lol)
#14 | |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Also, for centering rings, the best ones are polycarbonate, because they won't melt like plastic or rust on like metal rings.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#15 |
![]() ![]() Drives: an egg Join Date: Aug 2010
aren't the metal rings that are used aluminum? those shouldn't rust anyway.
#16 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
After that experience, I took a closer look at the rings, and IMO, they are totally unnecessary. Tapered lugs will center your wheels fine. Shanked lugs will center your wheels fine. If your wheels are made so badly that the lugs do not center the wheel, adding rings won't help since, if you install metal hub centering rings, the lugs will no longer seat correctly. On my Volks, the lugs center the wheel so perfectly that when the lugs are torqued down, the hub centering ring is loose in the bore and can be spun inside the bore with my finger. You're better off spending the money buying the center caps (if they aren't included); then you won't get water in there causing the brake hat or drum to rust to the hub. |
#17 |
if you want a fun experience with galvanic corrosion, try to take the rear wheels off a dually truck.....
| TRADE: My Wheels for your Stock Wheels... | FF_Attack | Items for Sale by private party | 9 | 04-10-2010 05:04 PM |
| Feedback on these wheels | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-04-2007 08:09 PM |
| Center bore? | Walter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 02-17-2007 12:20 AM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
