Old 06-17-2011, 01:46 PM   #1
radlebaby
Drives: 2007 4 door sedan
Clunking????
Hey guys,
I just recently purchases a 2007 Certified Toyota Yaris 4 Door Sedan manual. I have driven a manual since I turned 16 and am experiencing a problem I have never encountered. When coming from a start (typically after starting the car) and starting out when I'm about half way released from the clutch in 1st I notice a clunking sound? Any suggestions as to why??
Thanks!!! :)
radlebaby is offline   Reply With Quote
Old 06-18-2011, 10:20 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
why don't you bring it to the dealer and let them hear it. If it's certified, there shouldn't be anything wrong with it.
Old 06-18-2011, 01:33 PM   #3
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
--how long ago?
--how old are you now?
--how many previous and what kind of cars did you own/drive prior A/T? M/T?
--does this happen only when pulling out in first gear ?
--could be a number of things i.e. bad motor mount(s),play/bad (in) swaybar endlink(s),etc
if you purchased this recently as you stated, take it back to where you got it from and voice your concern unless you bought it "as is".
if so look into a reliable repair shop
OTA'sTOY is offline   Reply With Quote
Old 06-22-2011, 01:12 PM   #4
AppleJacks716
Drives: 2010 5 Door
What are you a pedo bear?
I bought a 2010 new off the lot and it does the same thing. Its just the clutch grabbing. All the manuals on the lot did it, a yaris thing id imagine. I brought it up on the test drive and they pulled it into service. The techs said it was just the clutch engaging.
AppleJacks716 is offline   Reply With Quote
Old 06-22-2011, 02:28 PM   #5
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Yeah, due to the motor mount design, the motor moves a lot when you dump the clutch.
clunking sound
Front End Clunking Sound when hitting small bumps Arizona_Commuter DIY / Maintenance / Service 16 06-17-2011 12:32 PM
clunking sound 3stars_n_a_sun General Yaris / Vitz Discussion 7 03-11-2010 08:57 AM
