Old 07-01-2011, 12:15 AM   #1
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
Manual transmission problem
Sometimes when stopped with the clutch pushed in if you go thu the gears the trans feels like it gets tight won't go into 1st gear until you let the clutch out and push it back in then a little bit later it feels fine.This morning I drove to work 35miles away was going thu the parking lot in second gear stopped and tried to put in in first gear wouldn't go in until i let the clutch out and pushed back in worked fine on the way home have 100,003 mile on car trans oil changed at 75,000miles
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 07-01-2011, 12:27 AM   #2
RedRide
RedRide's Avatar
That is completely normal for most every manual trans.
You have to momentarily let the clutch out (like you described) to get the shafts spinning to enable the syncros to slip on to and engauge on the proper shaft.
In other words shafts usually have to be spinnning for syncros to function properely.
If gear teeth are not lined up via syncros, etc. you can't shift into that gear.
Somtimes when stopped, you can go through the gears without using the clutch and other times, you cant.
Like I said, it's normal.
Old 07-01-2011, 07:54 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
^+1^
Also notice if you ever have trouble getting it in reverse, put it in 4th and then try reverse again. will go in nice and smooth..
Old 07-01-2011, 03:29 PM   #4
RedRide
RedRide's Avatar
^+1^
What I do (if it wont go into R) is just let the clutch out for a second in neutral then, it will slide into reverse every time.
Old 07-01-2011, 11:23 AM   #5
gonzo452001
Thanks guys i was worried want to drive my yaris to at least 200,000 miles
oem style foglights
Scan GaugeII
Old 07-01-2011, 11:39 AM   #6
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
Take care of tranny man..... I already been through one......if you drive lot or you drive hard your car you might want to change your gear oil every 6 mos.... extend the life of it as much as possible ......... but if your problem worsens it might be a syncros wearing out or damaged ... I had that prob on my old tranny.......when it grinds to shift into gear worry.... lol
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 07-01-2011, 02:32 PM   #7
ilikerice
ilikerice's Avatar
+1
Old 07-01-2011, 04:14 PM   #8
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Just wanna confirm that this is normal, I had totally forgotten about it though because when I war learning how to drive a manual I was told to get into the habit of only putting it in 1st gear at a dead stop or going veeeeeery slow.
- Jason
2007 Toyota Yaris Liftback Base 5 Speed.
Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust.
Kiteless is offline   Reply With Quote
Old 07-01-2011, 05:57 PM   #9
str8Yaris
str8Yaris's Avatar
- Jason
Yea that good... that's what I do... or neutral ....
Blitz S/C @ 9psi
Vegas meet 2011
Old 07-05-2011, 11:05 AM   #10
RedRide
RedRide's Avatar
- Jason
Correct, this is to aviod putting a stain on the syncros.
Never try to force it into any gear.
Old 07-03-2011, 09:27 PM   #11
thepartsmancometh
Drives: '08 LB, '07 WRX
try driving a wrx! first is dead stop only unless you double clutch it. ahhhh...the idiosyncrasies of subaru 5 speeds!
thepartsmancometh is offline   Reply With Quote
Old 07-04-2011, 12:51 AM   #12
swidd
Drives: Yaris HB
To get slightly smoother gear handling try just oiling and lubing the gear linkage on top of the gear box... WD-40 and some lube.
swidd is offline   Reply With Quote
Old 07-04-2011, 01:34 AM   #13
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
What kind of driving requires a gear oil change every six months? It seems like overkill.
Old 07-04-2011, 09:17 PM   #14
str8Yaris
str8Yaris's Avatar
Not if u want your tranny to last u a long time.... if u drive a lot or drive it hard or both its good to change it.... I drive a lot & I take it to the track occasionally .... I'm going to start doing it...its good to have fresh oil in there......
Blitz S/C @ 9psi
Vegas meet 2011
Old 07-04-2011, 09:09 PM   #15
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
one that doesn't use a clutch to shift
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 07-04-2011, 11:12 PM   #16
rningonfumes
Okay, I can understand a track car and hard shifting but not the "drive a lot". There's a reason why they make it a semi-pain to change the gear oil.
Old 07-04-2011, 11:49 PM   #17
shouldnt the manual transmission fluid be changed every 40000miles?
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 02:30 AM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 09:08 PM
manual transmission squeaky Rich k DIY / Maintenance / Service 2 07-14-2009 12:34 AM
Is this normal in Manual transmission? Syroyizhka DIY / Maintenance / Service 16 04-02-2009 02:19 PM
Detailed dealer pricing on the new, 2007 Toyota Yaris. tomjasz New YARIS Purchase Forum 3 08-11-2006 11:46 PM
