Old 07-07-2011, 08:57 PM   #1
ladyKay
Drives: 2008 yaris sedan
Talking installing daytime lights to 2008 Yaris Sedan
Hello,
This is my first time posting on here. I may need to relocate soon and regulations to the new location will require daytime running lights. I would prefer to keep my car rather than trading it in for another one that is compliant... am rather attached to it
I am willing to pay a mechanic to do this for me (I am not qualified to do it and will certainly not learn enough on my own by the supposed deadline), just wondering if anybody out there has done it, or had it done, and if even could be done.
Thanks everyone!
PS Sorry if this was already posted somewhere... I couldn't find the search function to see if this post already existed.
ladyKay is offline   Reply With Quote
Old 07-08-2011, 07:25 PM   #2
thetut
Drives: 2007 4dr sedan
Where are you locating to?.
When you bring your car into a new jurisdiction, it usually means that it will have to be certified by the local authority. The work to be performed to achieve the certification is usually carried out by garages recommend by the authority.
thetut is offline   Reply With Quote
Old 07-08-2011, 07:59 PM   #3
You can easily have these added and put them with your parking lights or on their own switch:
http://shop.microimageonline.com/DRL...ts-RTDL-01.htm
Old 07-10-2011, 06:41 PM   #4
ladyKay
from USA to Canada. Figure I'd save myself the hassle of the deadline by having the work done first, when it's first imported over.
Old 07-10-2011, 06:41 PM   #5
ladyKay
I'll check it out. Thank you!
Old 07-10-2011, 11:20 PM   #6
carnageehw
Drives: 2010 Fusion Hybrid
Daytime running lights aren't mandatory in most areas.
carnageehw is offline   Reply With Quote
Old 07-11-2011, 08:10 AM   #7
shameer_k
Drives: yaris sedan
i found these last night
http://www.alibaba.com/product-gs/46..._headlamp.html
they install on the lower grill
shameer_k is offline   Reply With Quote
Old 07-11-2011, 12:46 PM   #8
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Actually, mounting the DRL lights seperately is the easy/fun part, it's the wiring logic that makes this a bit of a challenge. However, if you know how a standard automotive relay work and know how to tap to your fusebox wiring then it should be a breeze.
As soon as you start the car, you would want the DRL to come ON automatically if the headlights are in the OFF position (no fiddling with switches, etc.) and you want the DRL to turn OFF automatically when you turn your headlights ON.
Relay Wiring for DIY LED Daytime Running Lights (DRL)
-toy
Old 07-11-2011, 02:26 PM   #9
fj40dave
fj40dave's Avatar
Drives: '08 HB
If you're close to the Seattle/Tacoma area, I can give you a hand with getting it installed.
I took out the DRL relay that my '08 HB came with....does your's not have one? Maybe it's just unplugged? (thinking with my fingers here [aka: outloud])
Dave
fj40dave is offline   Reply With Quote
Old 07-11-2011, 08:45 PM   #10
thetut
This is where I would start - http://www.tc.gc.ca/eng/contact-us.htm
If you can bring in your car temporarily I understand that Canadian Tire outlets are approved to make the appropriate modifications.
Old 07-12-2011, 05:29 PM   #11
MUSKOKA800
MUSKOKA800's Avatar
Lot's here run with them disabled because they're uncool.
Likely you just need the DRL module (that we can remove to kill ours) to activate yours.
Tags
daytime lights, lights
would the tc tail lights or wing fit the sedan yaris? evilekhatch General Yaris / Vitz Discussion 14 03-15-2010 09:28 PM
duda con 2009 yaris sedan fog lights dassoe09 Caribbean 17 06-14-2009 02:56 PM
