YarisWorld,
Could you please post your Bumper Cover Push type Clip or retainer P/N 90467-07071-22 alternative? Bumper Cover Push-Type Retainer Black Nylon Head Diameter: 11mm Stem Length: 14mm Fits Into 7mm Hole Replaces Toyota: 90467-07071-22 Yaris 2009 - On ![]() borrowed from kw531 post ![]() We have used the Hyundai/Kia bumper retainer/Clip as it has far more better grip than toyota and it has a Philips head: ![]() ![]() T = 18 мм. F = 8 мм. H = 15 мм. D = 11 мм. If you replace yours with a Metal one, could you please share the solution? TIA |
![]() ![]() ![]() Drives: oliveMist Join Date: Apr 2011
@kiel12 and @rufnnek
Pls reply in English for this thread. Thanks in advance. --ricepower |
![]() Drives: 2007 Manual Bayou Blue LB Join Date: Jul 2011
I just replaced mine today after doing the headlamp replacment...low beam wasn't working on the driver's side.
I went with a replacement that had a larger in diameter "washer". 3 of the original 5 were missing. Got mine from NAPA with a part number of 6651316. |
| Tags |
| bumper clip, bumper retainer, push on clip |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 07:42 PM |
