![]() Drives: 2009 5dr hatchback Join Date: Jun 2010
new springs, abs light
Hey guys, just installed some new springs with OEM struts and the ABS suddenly came on. Any idea what this could be?
You may have accidentally popped off one of the 4 ABS sensor connectors.
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
Or you pulled a wire out in the rear. When changing the rear springs, it's very easy to un-bolt the struts, and let the axle just drop down. Unfortunately, it pulls on the ABS wires.
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
I had this happen too. I had crimped the abs wire which broke it. I had to buy a new abs wire.
Tantum religio potuit suadere malorum. |
Thanks ill have to check that out. And the creeking noise from the new springs is all part of 'breaking it in'?
^ Go drive the crap out of it, lots of turns, let them settle.
Oh good. So thats normal then? Was scared my tires would fall off or something. lol. its the MI springs btw :)
just took another look under the hood and i can see the strut poping out a 1cm or 2. could it be a tightening problem?
^. Correct, 100% normal.
Make sure your lug nuts are tightened and torqued. That can cause creaking. I know I've driven off with hand tightened ones before.
DAT'S RIGHT I GOTz 2
are you sure 1-2cm(1/2"-3/4")gap seems abit excessive i could see 1cm at most
Thanks guys. Springs were on backwards -.- The one post on MI.com got me confused lol. No creaking noises. Ride is unbelievably awesome. Just the ABS light is on. Anyone know where the sensor is located? pics?
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Have a look at the Brake Control pdf, maybe that will help?
http://www.etimago.com/yaris/repairm...%20Control.pdf or peruse the other sections of the Service Manual: http://www.etimago.com/yaris/repairmanual/ Maybe you can take some pics while you are in there, too. |
#14 | |
| HELP / Spoiler connecting light | SimTronik | DIY / Maintenance / Service | 4 | 11-03-2010 12:08 AM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 02:49 PM |
| Parking Light Flash Output vs Hazard Light Output | sex | DIY / Maintenance / Service | 2 | 11-03-2009 09:47 PM |
| Emergency brake light is on constantly | AdeJong 03 | DIY / Maintenance / Service | 9 | 10-10-2009 10:32 PM |
| '09 Fog light replacement | Mavix | Cosmetic Modifications (Exterior/Interior) | 5 | 10-07-2009 04:21 AM |
